Username: zach_attack
Xterra's Nickname: Adventuremobile
Comments:I joined this forum back in July 2016 after a number of issues that I googled for found succinct and more importantly accurate answers followed by thoughtful discussion on this site. Many thanks to all who have helped me along this path, whether you know it or not.
Purchase: 2007 Nissan Xterra Off Road 4.0L 4wd 6speed with 80,000 miles (July 2016)
Factory options: Clutch start cancel, Fog lights, Fold flat passenger seat, Rear differential E-locker, Rockford Fosgate subwoofer & 6-CD changer
Legend:
Armor/Off-road Bolt-Ons
Exterior
Interior
Lighting
Powertrain/Under The Hood
Tires/Suspension
Maintenance
Lottery List - $$Most of this stuff probably won't get done unless I either win the lottery or absolutely have to do it$$
..Year: 2007
..Make: Nissan
.Model: Xterra
..Trim: Off-Road - Titan Swap
.Color: K12 Radiant Silver Metallic
Weight: 4600lbs
..Make: Nissan
.Model: Xterra
Weight: 4600lbs
Legend:
[+] = Done
[- ] = Purchased/pending install
[. ] = Want
[x] = Removed/destroyed/sold
Index of How-To's
My OCD requires me to list mods in alphabetical order
[. ] = Want
Index of How-To's
[+] -Hardcore Offroad steel front bumper
[+] -Hardcore Offroad rear tire carrier bumper
[+] -Hardcore Offroad sliders [+] welded +2 inches
Skids
[+] -Hardcore Offroad radiator skid
[+] -Hefty engine skid
[+] -Shrockworks transmission skid
[+] -Hefty transfer case skid
[+] -Shrockworks gas tank skid
[+] -Shrockworks rear diff cover
Exterior
[+] -2" BL - DIY
[+] -Bedlined gas door, side moulding, rocker panels, roof channels
[+] -Crawlorado hood blackout
[+] -Gobi Ladder (thanks Nexterra, ECXC 2017)
[+] -Gull Wing window [+] 2.0
[+] -Hella Supertone horns
[+] -Locking wet box
[+] -Side turn signals
[+] -Stubby antenna
[+] -Tail light guards
[+] -Ventvisors
[+] -Stubby antenna
[+] -Ventvisors
Interior
[+] -Anytime windows mod
[+] -Clutch Start Cancel relocation to center
[+] -Custom cell phone mount
[+] -Custom wastebasket
[+] -Dashcam (hardwired)
[+] -Heps designs rear window molle panel (thanks GPAX, Shocker Run 2017)
[+] -Heps designs head rest hook (thanks GPAX, Shocker Run 2017)
[+] -LOBO shelf
[+] -Mesh door pockets
[+] -Non-slip cargo area
[+] -"Passenger Airbag Off" Light Shut-off Mod (A.K.A. a girlfriend)
[+] -Rear hatch exit from the inside mod
[+] -Rear hatch latch torx bolts replaced with 13mm hex bolts
[+] -LOBO shelf
Entertainment
Gear
[+] -Infinity Reference 1262w 12" subwoofer
[+] -Rockford Fosgate 1.0 farad capacitor
[+] -SSL EVO 1500w amp mounted in first-aid kit cubby
[+] -Subwoofer switch (in dash)
[+] - Uniden Pro505XL CB with 2' Antenna
Gear
[+] -Automatic tire deflators
[+] -Fire extinguisher
[+] -Jumper cables
[+] -LED flashlight
[+] -Military grade laser pointer
[+] -Molle pouches (holding tire chain tighteners, pocket chainsaw, and ratchet straps)
[+] -Mounted hammer
[+] -Mounted hatchet
[+] -Mounted Maglite
[+] -Mounted shovel (thanks quickfists)
[+] -OBA for the RF equipped X (Pittsburgh Tools 150 psi compressor)
[+] -OBDII Bluetooth code reader
[+] -Recovery strap - 30'
[+] -Spline drive lug adapter
[+] -Tire chains
[+] -Various gloves
[+] -Jumper cables
[+] -LED flashlight
[+] -Mounted hammer
[+] -Tire chains
[+] -Various gloves
Lighting
[+] -Anytime fog lights
[+] -Baja Designs rock lights
[+] -Center console orange LED
[+] -eBay $2 awesome fog lights
[+] -LED interior lights
[+] -LOBO shelf LED Lights
[+] -Flush mount LED reverse lights
[+] -Underhood lighting
[+] -Xoskel lopro light rack with 4 Auxbeam pods
[+] -ABS Off Version 3
[+] -Anytime locker mod
[+] -Evap Purge Valve Breather Extension [P0448]
[+] -Factory air box mod
[+] -Front diff breather filter
[+] -Hood rod mod
[+] -IMS
[+] -K&N drop-in air filter
[+] -Magnetic oil drain plug
[+] -Oil catch can
[+] -Offroad Gorilla Silicone Hoses -Red
[+] -PRG motor mounts
[+] -Rear diff breather
[+] -Xterra Battery Tie Down - The Band-Aid
[+] -Hood rod mod
[+] -IMS
[+] -Oil catch can
Tires/Suspension
Front
[+] -Factory Toyota Tacoma front springs
[+] -Factory Toyota Tundra front struts
[+] -PRG stainless steel extended front brake lines
[+] -PRG tie rod extenders
[+] -Rough Country Titan UCAs
[+] -Rugged Rocks extended CV axles
[+] -Stock Titan LCAs
Rear
Rear
[+] -4º shims
[+] -Deaver dual add-a-leafs
[+] -Helwig add-a-leaf
[+] -PRG adjustable shackles (top hole)
[+] -PRG U-bolt flip
[+] -Bilstein 5125 rear shocks
Maintenance
[+] -Cabin air filter [95K], [112K], [129K]
[+] -Brake pads, front [112K], [132K]
[+] -Brake pads, rear [129K]
[+] -Brake shoes, parking [129K]
[+] -Catalytic converters, both primaries [134K]
[+] -Front driver wheel bearing [103K]
[+] -Front passenger wheel bearing [110K], [123k]
[+] -Front driver UCA replacement due to bad ball joint [105K]
[+] -Fuel pump [110K]
[+] -PA State Inspection [05/25/17], [07/01/18]
[+] -[P0448]
[+] -[P0452]
[+] -[P0850]
[+] -Radiator [106K]
[+] -Reattach tailpipe [5/6/17]
[+] -Replace bad A/C o-ring and recharge system [5/17/17]
[+] -Serpentine belt + tensioner [100k]
[+] -Spark plugs [100k]
[+] -Sway bar endlinks
[+] -Transfer case drain plug replaced [112k]
[+] -[P0448]
[+] -[P0452]
[+] -[P0850]
Fluids - Product - [Mileage]
[+] -Brake & clutch fluid - Prestone - [118K]
[+] -Power steering fluid - ATF - [118K]
[+] -Coolant - Peak Long Life + Distilled Water - [103K], [113K], [133K]
[+] -Engine oil - Castrol Edge Synthetic 5W-30 High Mileage - [108K], [113K], [118K], [123K], [129K], [134K], [140K]
[+] -Freon - [112K]
[+] -Front diff - Valvoline Durablend Synthetic 80W-90 API GL-5 - [108K]
[+] -Rear diff - Valvoline Synpower Synthetic 75W-140 API GL-5 - [95K], [113K], [146K Royal Purple]
[+] -Transfer case - Valvoline Maxlife Synthetic ATF - [108K], [112K]
[+] -Transmission fluid - Nissan 75W-85 MTF 999MP-MTF00NP - [120K]
[+] -Freon - [112K]
[. ] -35s
[. ] -4.56s
[. ] -Bullydog tuner
[. ] -Dephep roof rack
[. ] -HIDs
[. ] -Illuminated shift knob
[. ] -JWT clutch/flywheel
[. ] -Seat covers
[. ] -Timing chain fix
[. ] -Touchscreen head unit with hard drive
[. ] -4.56s
[. ] -HIDs
[. ] -Seat covers
