I don't know if any of you guys did this, but I figured out a way to make the Diff Light on the Instrument Panel to work with the ARB Air Locker.
Unfortunately didn't take any pictures but with the following diagrams you'll be able to get it running.
The "Diff Lock" Light on the Instrument Panel goes on Pin #25 of the Harness.
The Amber "Diff Lock" Light on the Instrument Panel turns on when its Grounded, however the Rocker Switches of the Air Locker all give 12v Positive. The work around to this is to wire it up with a Negative Activation Relay.
Port 87 goes to Pin #25 on the Instrument Panel Harness. (On my S Trim Xterra this Pin was empty so I just pushed a wire into the harness.)
Port 86 comes from Port #3 on the Locker Rocker Switch.
Port 30 and 85 from Relay goes to Ground or Port 8 on Locker Rocker Switch.
Now when ever you turn on the Air Compressor, THEN you turn on the Rear Locker the Amber "Diff Lock" Indicator will light up on the dash!!!
Cheers!!!!
Cheers!!!!
