** The Dumb Question Thread **
252K views 1.7K replies 177 participants last post by  eighty
#1 ·
Sometimes I've got a question and there's no handy place to ask it...
I've been wondering about this for a while... Why do the P4X guys care that the roof lights only come on with the high beams on? What situation do they get into that they want low beams and roof lights on instead of high beams?
#61 ·
I don't like receiver rust. I can only think of two solutions.
I can clean the rust out, paint, repeat as needed. Not wild for this because I think it will need done twice a year.
I could also clean up the rust and then grease it, but I use too many different ball mounts and hitch haulers. There would be grease everywhere in the back of the X and the garage.
Anybody have a good option three?
#74 ·
Oil?
I don't worry about it on mine.
#63 · (Edited)
This may be a particularly dumb question, but it possible to body-lift half of the X?
Like say you have a 6" lift in the rear, but 3" in front and want to clear for 35's but don't need anymore height in the rear. Can you just do a BL on the front-half?
My guess is "no" because all the bolts would be at too much of an angle making it too easy for them to shear off, but I'm not sure.
#76 ·
The receiver rust question got me thinking. Do other steel components like sliders and bumpers rust as fast as receivers seem to? I'm in the Northeast and road salt is liberally applied here (though I do regular underbody washes in the winter). I am about to order sliders and a rear bumper and was wondering if I'll always be dealing with corrosion on those parts.
#84 ·
I would be most interested to somehow force the intermittent setting for the rear wiper to base its delay time off of the front wiper.
I've had that exact same thought.
All I want is infinite adjustability for zero dollars spent. Is that so much to ask?
#88 ·
Hopefully this isn't the dumbest question in this thread...
When people refer to seized cam bolts, what exactly gets seized? Is it the nut, or the bolt inside the arm.
I feel like it has to be the bolt that is seized inside the lca. No nut on my X has stood up to the 8ft breaker bar yet and I'll be damned if this is the one to do it.
#90 · (Edited)
Question about Drop Bracket travel
I have a question about suspension travel and drop bracket lifts.
Imagine you have the coilover out in front. The CV binds here (Titan swap):
However, when moving the hub upwards, you find that full "stuff" is actually not at bind of the CV joint, but instead where the bump-stop on the LCA hits. You can probably get 50% more up-travel if there was nothing in the way before the CV binds. In fact I'd say the CV is closer to neutral than it is to the binding point when at max up-travel.
This pic is maximum up-travel:
Now on my Titan swap, with ideal setup I have around 10"-10.5" of travel, and the CV at ride height is angled downward.
If you add a drop-bracket lift and make the CV angle "neutral" at ride height, would you be able to get more up travel because you have more room before you hit the bump-stop? Could you get to like ~14-15" of travel this way if you used a longer coilover?
:confused:
#91 ·
the bump stop is there to protect the coilover from crushing itself. The length of coilover is what limits the up travel (usually down travel is maxed out on the titan swaps). A drop bracket can give you more travel because you can get a longer coilover in there now. How much more? I have no clue.
#97 ·
I love this thread. I get to think out loud along with you and hopefully nobody judges too harshly.
So given that and what Albatross and others have said, the ideal setup with the drop bracket would be an relatively level CV angle at ride height, with a coilover compressed to approximately half its available travel? And overall coilover travel limited to just within CV bind angles at full stuff and full droop? Sounds great on paper in terms of having maximum articulation up and down. But, this is coming from a guy who's happy with the hunk of aluminum on top of his stock coilovers and just glad it doesn't go THUNK when I go over bumps.
#92 ·
i think it would indeed allow for more up travel but might even reduce your down travel.
stock the LCAs and CVs are in essence parallel: Distance between CamBolt to Diff flange is the same/close to the LBJ and Hub
drop bracket you are now increasing the distance between CamBolt and Diff flange and keeping the LBJ and Hub so your CV would bind sooner than in stock.
unless you did a diff drop kit which would then cancel it out some.
#93 ·
I always thought "diff drop kit" and "drop bracket" were synonymous... is that not right? Don't think you would do one without the other.
#98 ·
I guess it depends on what your goal and needs are. I play in the rocks, and decided against the drop bracket because I want as much clearance as possible up front without being too tall. It would be nice to get the "belly" of the xterra up higher though.
#102 · (Edited)
#106 ·
There is no way you can run 35's without a BL on a TS without trimming the top of the fender without severely limiting up travel. I'm pretty sure 35's are still going to rub mine even with the 2" BL
Oh, and hardcore makes BL brackets for your bumper to lift it up. I'll have mine in 2 weeks or so.
I thought VERY hard about doing a TS + Drop bracket, but after talking to golf286 and looking at everything the rear needs to get it up high enough (pretty much have to SOA, which I'm not a huge fan of), I decided to stick with TS + BL instead.
