This is a the 2011 follow on report for temperature measurements of the ATF and engine cooling systems last year , http://www.thenewx.org/forum/showthread.php?t=30287.
I can measure up to eight channels with two data loggers. I have thermocouples at:
1. Trans cooler line out
2. Rad cooler in
3. Rad cooler out (Air cooler in)
4. Air cooler out
5. Trans cooler line in
6. Trans pan
7. Engine coolant out of radiator at thermostat
8. Air temperature in front of Air-ATF cooler fan
9. Engine coolant into radiator, this measurement agreed with the ScanGauge value
I added a thermostatically controlled fan to the Air-ATF cooler, http://www.thenewx.org/forum/showthread.php?t=36953 . My X is an 09 with about 17K miles and a stock cooling system except for the fan. The ATF cooler in the radiator is still functional. I did a complete FSM manual flush of the transmission and a flush and refill of the coolant system last fall.
Being able to measure time synchronized temperatures at the various points and then review the data gives a reasonably clear picture of the thermal behavior. There is much interpretation of the data because there are other factors that aren’t being recorded directly; such as throttle position, road grade, vehicle and engine speed, and transmission gear.
Some observations based on the latest data. I’ll explain in more detail when described the data plots.
The cooling system works very well with a large margin for added load during low speed and high ambient temperatures. The few times it has gone over 200F for brief periods it has always cooled back to the 195F range.
The fan on the Air-ATF cooler has added real cooling capacity. While I’d prefer to keep the ATF temperature below 175F, that isn’t necessary. The cost to do so would be prohibitive. The fan does minimize the time above 175F.
There is no doubt to me that the Rad-ATF cooler is performing a needed function. Bypassing the cooler and just running the Air-ATF cooler alone is limiting the cooling capacity. This doesn’t mean there will be an imminent failure but the ATF and transmission will be definitely running at higher temperatures than designed. If I was going to modify the transmission cooling system by bypassing the radiator cooler I would add a fan to the factory air cooler and add an additional air cooler.
The heat from the ATF can significantly increase the temperature of the coolant leaving the radiator. It doesn’t seem to cause a problem for the cooling system to control the engine temperature. Increasing the cooling of the ATF with the addition of a fan on the Air-ATF cooler helps reduce the cooling load on the engine coolant system.
Stop and go driving is severe use in high temperatures. When coming to a stop the temperature out of the trans starts to rise and continues until the vehicle is moving again if the start is gentle. A hard start adds to the thermal load. While stopped, the is no airflow through the Air-ATF cooler and minimal cooling. The rad provides the majority of cooling during this time.
Driving between 40 and 65mph in 5th is light duty use. The converter is locked and there is minimal heat produced. During these conditions, regardless of ambient temperature the Air-Rad cooler alone would probably be adequate.
These plots are driving North on US89 to Page and beyond from the intersection of US160 and US89 near Tuba City. There was road construction with a stop and then following a safety car at about 25mph. There is a steep climb to Antelope Pass. The climb was at 55-60mph in 3rd gear.. Even with the steep climb the coolant only got to about 205F briefly. After the pass the road is mostly downhill from 6100 feet to Page at about 4000 feet, at about 14:50 on the plot. From Page the highway crosses Glen Canyon Bridge at 25mph and then climbs up to the mesa on the west side of the river.
These plots are the trail up Smoky Hollow Canyon to Smoky Mountain Road. It was done in 4HI and D at 15-20mph with the AC on. To check the effectiveness of the added fan, I pulled the fuse when the fan was running and continued driving uphill. The fan was left off for about 20 minutes and then reconnected. The ATF temperatures gradually increased until the fan was running. The temperatures stabilized until the last steep climb out of the canyon leading to the mesa. Coolant temperatures increased slightly during the climb, but stayed in a comfortable range. Once on the mesa, the road leveled out and the temperatures rapidly dropped. There were some gradual up- and down-hill grades on the mesa.
This plot is city driving after the engine and trans were completely warmed up in 99-101F weather. AC was off and in D. The grade was uphill with regular stop at traffic lights. The fan dropped the ATF temperatures in both the pan and out of the trans to the coolers.
These plots started with a cold start and gentle city driving as the engine and trans warmed up. At the point on the plot marked Central was where the uphill grade started. The road becomes the frontage road and there was minimal stops until reaching the high point at Sedillo Hill. AC was off, trans in D, and driving mainly in 5th at 50-55mph. Even though the ambient temperature dropped with increasing altitude, it was still around 90F.
Driving back downhill the engine and trans cooled off. It’s typical for the engine to cool down to 185-190F on downhill runs, regardless of ambient temperatures. Back in town the trans started to heat up in stop and go traffic along with the air temperature around 100F. Once the fan turned on the temperature stabilized. Stopped in traffic, the air temperature can rise significantly from the vehicles in front of you. The coolant temperature from ScanGauge never got above 200 for the entire trip.
Something I am considering is to reverse the ATF flow between the air and rad coolers. I’d run the ATF through the air cooler first and then the rad cooler. The higher temperature ATF in the air cooler should improve the heat loss and lower the heat load on the engine cooling system. Whether it would be a wash because the hotter air from the air cooler would be flowing through the radiator is a reasonable question. To swap the hoses requires the NXRocks rad skid to be dropped which is a job. Based on my data there doesn’t appear to be any cooling issues for me that require additional modifications, but it is something I’m thinking about.
I’ll try to answer any questions.
Cheers,
Jeff
2. Rad cooler in
4. Air cooler out
6. Trans pan
Cheers,
Jeff
