Disclaimer:
These numbers were pulled manually from the 2005 Nissan Xterra Service Manual (revision Feb. 2006). There could be errors in translation, typos, misreading of the manual, brain farts, etc. Please double-check these torque specs with Nissan. I take no responsibility if you use these specs and something falls off.
I will add to this over time. If there is anything I am missing or someone sees that is wrong, please let me know and I'll add it.
Front Suspension:
Swaybar Mounting Brackets: 96 ft-lbs [FSU-5]
Swaybar Connecting Rod (Both Ends): 62 ft-lbs (Replace After Removal) [FSU-5]
LCA Bump Stop: 14 ft-lbs [FSU-5]
LCA Cam Bolt: 100 ft-lbs [FSU-5]
LCA Ball Joint Nut: 70 ft-lbs (Replace After Removal) [FSU-5]
UCA Mount Bolt: 94 ft-lbs [FSU-5]
UCA Ball Joint Nut: 58 ft-lbs (Replace Cotter Pin After Removal) [FSU-5]
Lower Shock Mount: 98 ft-lbs [FSU-5] Upgated 13Jun2025 - Old Navy
Upper Shock Mount Nuts: 22 ft-lbs (there are 3 nuts) [FSU-5]
Shock Upper Spring Seat Nut: 30 ft-lbs (Replace After Removal) [FSU-5]
Wheel Hub Mounting Bolts: 44 ft-lbs (there are 4 bolts) (Replace After Removal) [FAX-5]
Center Hub Nut: 101 ft-lbs (Replace Cotter Pin After Removal) [FSU-5]
Rear Suspension:
Bump Stop: 14 ft-lbs [RSU-5]
Swaybar Mount: 36 ft-lbs [RSU-5]
Swaybar Connecting Rod Nuts: 32 ft-lbs (Replace After Removal) [RSU-5]
Upper Shock Mount Nut: 33 ft-lbs (Replace After Removal) [RSU-5]
Lower Shock Mount: 148 ft-lbs [RSU-5]
Spring Shackle: 77 ft-lbs (Both upper and lower) [RSU-5]
Front Leaf Spring Mount Bolt: 84 ft-lbs (Replace After Removal) [RSU-5]
Axle U-Bolt Nuts: 53 ft-lbs (Replace After Removal) [RSU-5]
Dynamic Dampener (weight): 14 ft-lbs
Front Diff (R180):
Diff Mounting Bolts: 135 ft-lbs [FFD-14]
Crossmember Bolts: 96 ft-lbs [FFD-14]
Pinion Nut: 138-216 ft-lbs (Replace After Removal) [FFD-16]
Ring Gear Bolts: 43 ft-lbs [FFD-16]
Carrier Bearing Journal: 69 ft-lbs [FFD-16]
Diff Cover Bolts: 30 ft-lbs [FFD-16]
Rear Diff (C200):
Pinion Nut: 107-238 ft-lbs (Replace After Removal) [RFD-15]
Ring Gear Bolts: 58 ft-lbs [RFD-15]
Carrier Bearing Journal: 69 ft-lbs [RFD-15]
Axle Bearing/Hub Nuts: 49 ft-lbs (there are 4 nuts) [RAX-7]
Diff Cover Bolts: 36 ft-lbs [RFD-15]
Rear Diff (M225 w/o Locker):
Pinion Nut: 220-500 ft-lbs (Replace After Removal) [RFD-50]
Ring Gear Bolts: 133 ft-lbs (Replace After Removal) [RFD-50]
Carrier Bearing Journal: 80 ft-lbs [RFD-50]
Axle Bearing/Hub Nuts: 89 ft-lbs (there are 4 nuts) [RFD-50]
Diff Breather: 31 in-lbs [RFD-50]
Diff Cover Bolts: 31 ft-lbs
Rear Diff (M225 w/ Locker):
Pinion Nut: 220-500 ft-lbs (Replace After Removal) [RFD-123]
Ring Gear Bolts: 135 ft-lbs (Replace After Removal) [RFD-123]
Carrier Bearing Journal: 80 ft-lbs [RFD-123]
Axle Bearing/Hub Nuts: 87 ft-lbs (there are 4 nuts) [RFD-123]
Diff Breather: 31 in-lbs [RFD-123]
Locker Wire Harness: 89 in-lbs [RFD-123]
Diff Cover Bolts: 31 ft-lbs [RFD-123]
Front Driveshaft:
Flange Nut: 44 ft-lbs (Replace After Removal) [PR-5]
Rear Driveshaft (Model 2S1330):
Flange Nut: 71 ft-lbs (Replace After Removal) [PR-10]
Rear Driveshaft (Model 2S1330-BJ100):
Flange Nut: 41 ft-lbs (Replace After Removal) [PR-11]
Front Brakes:
Slide Pin Bolt: 32 ft-lbs [BR-22]
Torque Member Bolt: 136 ft-lbs [BR-22]
Union Bolt: 24 ft-lbs [BR-22]
Bleed Valve: 69 in-lbs [BR-22]
Rear Brakes:
Slide Pin Bolt: 19 ft-lbs [BR-28]
Torque Member Bolt: 76 ft-lbs [BR-28]
Brake Line: 19 ft-lbs [BR-28]
Maintenance:
Engine Oil Drain Plug: 25 ft-lbs (Replace Crush Washer)
Transfer Case Fill Plug: 26 ft-lbs (Replace Gasket)
Transfer Case Drain Plug: 26 ft-lbs (Replace Gasket)
Front Differential Fill Plug: 25 ft-lbs (Replace Gasket)
Front Differential Drain Plug: 25 ft-lbs (Replace Gasket)
Rear Differential Fill Plug (C200): 36 ft-lbs (Apply Silicon RTV or Equal)
Rear Differential Drain Plug (C200): 36 ft-lbs (Replace Gasket)
Rear Differential Fill Plug (M226) (with or without Locker): 25 ft-lbs (Apply Silicon RTV or Equal)
Rear Differential Drain Plug (M226) (with or without Locker): 20 ft-lbs (Apply Silicon RTV or Equal)
Manual Transmission Fill Plug: 25 ft-lbs (Replace Gasket)
Manual Transmission Drain Plug: 25 ft-lbs (Replace Gasket)
Automatic Transmission Drain Plug: 25 ft-lbs (Replace Gasket) (both 2wd and 4wd models)
Engine:
Intake Manifold: Bolts: First Pass: 5 ft-lb Second Pass: 21 ft-lb
Intake Manifold: Studs: 8 ft-lb (If removed from Engine Block)
Intake Manifold: Bolt Pattern: Engine Front: 5, 3, 2, 7
Intake Manifold: Bolt Pattern: Engine Front: 8, 1, 4, 6
Misc:
Wheel Lug Nuts: 98 ft-lbs
Front Suspension:
Rear Suspension:
Front Diff (R180):
Rear Diff (C200):
Front Driveshaft:
Front Brakes:
Rear Brakes:
Maintenance:
Engine:
Misc:
