Thanks for the Cross Threaded Lug Nut Dealership
4.4K views 10 replies 9 participants last post by  SycoCell
#1 ·
I do most of the work on my X when I can. Unfortunately I don't have the ability to align or balance my own tires so I have the local Nissan dealer do those things for me. I have a great repor with the parts guy there so I figure why not give them.the busness?
Well I stopped in yesterday to get my tires rebalanced. Everything went quickly and I was pleased. Until this morning that is.
I don't know why but when I went out to my truck this am I kinda walked around it looking at the rims. When I got to the passenger rear I noticed one of the lug nuts looked crooked. Without thinking I grabbed my breaker bar and tried to loosen the nut. Well it turned 1/4 and snapped right off. With the lug nut now out I could see the paint around half of the hole the lug nut sits in is ground down to bare aluminum. I decided to check all the other lug nuts and while no others were cross threaded I could tell they were not torqued down evenly. Some came loose with hardly any effort while others were ridiculously tight.
Needless to say I'm quite displeased. The lug nut that was cross threaded was all the way on so the guy had to have sat there with his impact gun hammering it till it was tight on the rim. Based on the damage to the paint in the rim I have a feeling it was the first nut he installed. Just had the nut in the socket and tried to spin it on without hand threading it first. Something a novice working his first job at a tire shop would do.
Well I'm off to the dealer to get this addressed. Honestly I don't trust the balancing they did now either. If this guy was in such a rush he couldn't hand thread the lug nuts I wonder just how much he cared about balancing my tires to perfect zeros. I'll probably have them rebalance the tires in addition to installing a new study and nut. As far as the paint damage to the rim goes I don't know what I want to do. All of my rims are pretty scratched up from 130,000 miles of driving and countless tire installs, rotates and balances.
I have a feeling they will offer me some free services for my troubles but after today I'm never going there again. Cross threading a lug nut and then hammering it down all the way so I don't notice is total b.s. It would have been great it I discovered this when I needed to change the tire on the side of the road and all I had was the wimpy tools the factory jack comes with.
#2 ·
Sucks man. I've come to find that dealership tire guys are the worst. I don't think they hire quality in that department, or its a starting area for new guys. I now go to a dedicated tire shop for any balancing or mounting work.
The final straw was a similar instance with the dealership for my wifes car. New tires, need to be mounted and balanced. I even removed all the wheel weights prior and cleaned the rims - cause some guys are lazy and just add more weight to the old ones.
Car comes back with two tires on backwards. Freakin backwards. Come on. $900+ Michelins.
I get that tires are one of the lowest skill sets required when performing car maintenance. But they are high when it comes to safety - its literally what connects the car to the road. How many customers are driving around with backward, un-balanced, over or under torqued tires??
#3 ·
Well Im at the dealer right now waiting on my truck to get fixed. It's been fun so far. After speaking to the service manager he agreed to fix it right away. I asked him for 2 things in addition to replacing the broken stud and nut. 1, I don't want the same tech working on my truck again and 2, real balance the tires because I don't trust the work the first guy did. Again, he agreed.
What's got me ready to punch the crap out of someone is I've been watching the tech from yesterday who cross threaded the lug nut continuously go back and forth between the service manager and the guy who's now working on my truck obviously running his mouth about this isn't his fault. It's just obvious and it's ticking me off something fierce.
Well hopefully the new tech does a good job.
#4 ·
lol... if it was not his fault, then whose was it? That would be interesting to hear.
#5 ·
Sounds like one of the hourly tech kids or lube techs as I call them...the ones that use an 1/2" impact gun and sit there for a minute straight on the trigger tightening up the lug nuts. I scream at them across the shop to use a effing tq stick. Always use torque sticks or properly torque them with tq wrench. The studs are not the hard of a metal so they break easy if cross threaded.
#6 ·
Well the last part of this adventure ended with the different tech who "fixed" my truck trying to make it seem like cross threading the lug nut wasn't a big deal.
He decides to tell me how they replace broken studs on the rear of Xterras and Frontiers all the time. Some with only a few thousand miles on them. He proceeds to say they must be a weak design because they just snap off left and right. My response was simply "then you guys are doing something wrong cause I have 130,000 miles on my X and all the studs are (well were) original. He just gave me a dumb look.
Well of course the first thing I did when I got home was check the lug nuts one by one to make sure no more were cross threaded. None were but none of them were torqued correctly either. That's the best way to deal with a pissed off customer after you screwed up I guess. Half ass it again. Just unbelievable.
