So I'll comment a bit on this...
I've had my OME packs for over 70k miles now (Frontier mind you so some small differences). I've gone through 2 sets of bushings (only like $30 to replace), one set of anti friction pucks, many types of lube, and many pack re configs. I've learned some things over this time. Found that you can eliminate any
squeaking with some slight mods to the packs.
For squeaking:
Disassemble the pack and place one of
these between each leaf (not overloads). You'll need to drill the center hole of them slightly larger to go around the center pin. These make it so that each leaf only touches the ones around it at the center and at the anti friction pucks. No need for any lube between each leaf anymore after this. Also makes the packs more active due to less internal friction. Also if you are missing/ have worn anti friction pucks, the OME ones suck.
These are the ones I used to replace the original ones.
On the retainers, most of my plastic things have broken at this point and the side of each leaf rubbing here is where most of my noise squeaks come from. To fix this, get some 1" or so heat shrink tubing and put it on each retainer. It will last a year or so before it rubs thru.
These get rid of all squeaks assuming your u bolts are tight enough. All of the stuff mentioned above is borrowed from Chevy 1500 packs which are said to be some of the best made.
For popping/ balloon noises:
These come from the bushings nearly 100% of the time. The best way to solve is to disassemble and re lube with quality grease. This will last about 6 months before the noises come back. The best spray lube to use to shut them up for a few months is a wax motorcycle chain lube. This will quiet them down for a month or so. I'm still working on a long term fix for this but will be trying some things in a few months (greasable bolts, shackles, different/ rubber bushings).
