Old Man Emu CS061R Dakar Rear Leaf Springs
17K views 18 replies 11 participants last post by  sevenhelmet
#1 ·
#8 ·
I have the big brother of those, the OME HD version, which gives about 2.5" of lift in the back. I put Radflo coilovers on the front to level the truck. For me, they ride great with stock bumpers- it's stiffer than factory, but still comfortable and wheels great. The ones you posted should be less stiff and give about 1.5" of lift.
#11 ·
I've had OME leafs and bilstein 5125s in the rear for about a month now, they squeak like a banshee but no clunks or concerning noises yet. I haven't wheeled with them yet, but the on road ride is a huge improvement over stock. Also have heavy duty TJM coil overs in the front to support my shrock, which gave me a level stance. I'm totally satisfied :D
#13 ·
I just put in the OME leafs with Radflo 2.0 in the rear, with the TJM extended coilovers in the front. Have Hefty bumpers front & rear, winch in the front (no tire carrier on the back), full set of hefty skids underneath and sliders as well.
Utilized adjustable shackles in the back and with them set to 1", the truck now sits about 2.5" higher and near perfect level (very, very slight rake).
Super happy with the ride, haven't experienced excessive noise.
Long and short - LOVE the setup.
Would highly recommend adjustable shackles in the back rather than any kind of spacer...
#17 · (Edited)
It's interesting that some of these kits squeak and clank, and some don't. I installed mine last fall, it's quiet as a mouse. Greasable shackles in rear, the full LD setup from Cruiser Outfitters - ALL OME stuff, ubolts, shocks, shackles. Removed the rear sway bar. I bought mine after riding with jeff_redx last summer near Ouray, his has seen a lot more use than mine, still just as quiet. Torqued all bolts to FSM specs, continually checked the u-bolts for some time, they kept moving around and needed retightening a few times. I love it.
#19 ·
I took my rear sway bar off when I installed the lift. I'm using OEM shackles, I wonder if that has something to do with it?
Mine is fairly quiet for the most part, I just get an occasional single pop.
