81 - 92 of 92 Posts
this rig is beautiful dude. question about the OBA setup...which viair kit did you get? (i've been eyeing them up myself for a while) and it isnt an issue having the compressor exposed to the elements? i was planning on installing mine in the rear interior somewhere until i just saw where you mounted yours.
Discussion starter · #84 ·
@ bliss_x, I went with the viair Ultra kit. 200 psi pump and tank. Figure I'm putting in double the cu ft of air into the tank vs a 100 psi unit.
It's been under the back for a couple of years now. Intake tube and filter are behind LH tail light. Clean or replace foam filter every couple months.
Working great and no problems.
@cblaxx19, You are correct.
Discussion starter · #86 ·
Discussion starter · #88 ·
Thanks guys. Been a lot of work, but so happy with it in this stage.
Hey, congrats on the recognition! awesome rig! I was just wondering if you would tell me where they pic for your TOTY is from. Thanks.
Imogene Pass, nearing the top-ish from the Ouray side.
81 - 92 of 92 Posts
