Hitch Recovery Point
5.7K views 24 replies 15 participants last post by  Billoftt
#1 ·
Can anyone recommend that doesn't stick out 2" outside of the hitch receiver?
#9 ·
Not trying to ruffle feathers, and I know Canada does have proud military folk who have served (some members here). But, when the U.S. and Britain do most of the heavy lifting in terms of military spending and defense of the region, a country like Canada has more disposable income to spend on the good life. If you know what I mean?
We also have a better health care system (up to now). Washington could continue to screw that up.
#15 ·
Shear strength on a 5/8 hitch pin is around 30000 psi which is about the same as a steel 3/4 shackle. That said I would made sure you use a recovery strap Ann's not a tow strap whatever you use.
Putting a strap around the center of a hitch pin is not going to yield the same shear strength. You would be applying the force in the center of the pin far from the edge where it is "anchored", that is not actually shear. It will bend it far before that. Plus that number will depend on the grade of steel used.
More than likely you will bend the pin making it hard if not impossible to remove with out cutting. That is why grade 8 bolts are used in auto and fleet, they shear vs bending as a grade 5 or lower carbon steel would.
#16 ·
That's a fine one. I'm saying the Canadian exchange price isn't accurate. But most anyone will do, as long as it's a solid chunk of metal. I've always used the $10 one from Harbor Freight. But another member said he saw that one bend.
Anyway, don't be reluctant to buy the cheapest solid one.
#20 ·
#21 ·
When I first got the X I also wanted something like this. I strongly advise against it and instead attach the strap directly to the hitch pin. You can watch some of the Australian 4x4 channels on you-tube, they regularly recommend this and you can even find some recovers done this way. Is it ideal? No. Is it safer than some cheap equipment of unknown quality/strength? Yes.
When I was looking into this I found quality components for hundreds of dollars and then I found the 20 or 30 USD ones. In my case I was considering purchasing a "SmittyBilt" one. There are reports online of these breaking and snapping off. A snap recovery plus a heavy hitch breaking off is very dangerous.
I made the decision to use the high as described until I can afford a custom bumper. Either way, I strongly discourage from using a cheap/affordable high recovery point. If you don't know the brand, if the brand isn't proven in the field, than you do not know if you are getting a recovery point or a dangerous missile!
Red
#24 ·
Well take it for its worth; some dude online who may or may not know what he's talking about and may or may not be risking his safety as well as that of others by using any single piece of equipment. I've used [url="https://www.amazon.com/gp/product/B003ZE32F8/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1]this[/url] hitch from Amazon since May 2017. It is solid steel and feels very sturdy. It probably sticks out way too far for liking, but it doesn't really bother me.
My question is, do you guys spend hundreds of dollars on hitch accessories when looking to tow a boat, travel trailer, etc? I personally have purchased the properly rated Reese brand at Walmart or Autozone and simply called it a day. I've never had an issue in the past.
My experience with this combination has been positive but I've only ever had to use it once. We were on our way back from the China Man Ranch (you can Google the history of that place in rural California) on a rainy day. There was a foreign tourist in his rental Jeep Cherokee that had pulled to the side of the road and got stuck in the some sticky mud. While still on the pavement I pulled him out with this recovery point. I'm not sure how I would have done it without it. It's simply cheap insurance to me.
#25 ·
No need to get too pricey here. A 10,000 lb. weight rating is 10,000 lbs., no matter where you get it.
https://www.harborfreight.com/d-ring-receiver-hitch-66212.html
I have one, it works. Anything hanging back there is going to snag on rocks and drag through the mud anyway...
In hindsight, instead of opting for a Curt hitch when I did, I should have just went for a Maxterra replacement bumper. That's my recommendation based off of experience, just go ahead and give Maxterra a PM and order a powdercoated rear bumper from him.
