Extending the bumpstops.
985 views 3 replies 3 participants last post by  S_e_X-Terra
#1 ·
Guys, as you know i have a full set of alcan leaf packs in the rear and the PRG adjustable shackles fully extended. My bumpstops are definitely too far from the axle (I have the timbrens). Instead of the bumpstops stopping the axle from anymore uptravel... its my tires rubbing on the frame. I need to extend the bumpstops which will also enable me to get longer shocks (they are the limiting factor right now in down travel).
I have the little puck thing that came with the timbrens but Im missing one of the extended bolts so i cant put them both on, and they are a very strange thread pattern so im having trouble locating another bolt. But adding those will only help a little bit... im thinking i need to add at least one more inch even with the puck.
Any suggestions.... I think Calmini has some spacers that come with the xterra 5" kit (but i got the frontier kit which doesnt come with spacers). Is there an easier way that im missing?
