So I've only run through 4 tanks of gas since I bought it in November (good or bad depending on which angle you look at it) and I've read some threads on here on the premium vs. regular.
The first two tanks I ran regular and the the last 2 tanks had premium. The first two I got in the 17's but the first tank was getting it home from the bay area, all up hill and such so not sure it means much. The last two tanks have been 91 vs. 87 octane for the first two, with the premium tanks yielding in the 19's with some highway cruising mixed in. Also the two premium tanks came after the timing chain fix, so not sure if that actually plays into it.
I know some people say the premium makes it run a little smoother and produce more power (which the manual recommends high octane for best performance) but I haven't noticed that at all. Maybe it takes a few tanks to yield those results?
I guess I'm impatient to do my own experimentation because it will take a year to get some good comparison data since I go over a month between fill-ups on it. What are your results with the whole Premium vs. Regular? For me its only a few extra bucks a month, but still dont' want to run something that's not necessary.
I don't know, maybe its been run on cheap 87 octane all its life by the previous owner and I should just sea foam it and then start running premium? Its not sluggish or anything, and I'm getting decent mpg's, I'm just not noticing a difference at all on premium.
