My 2008 offroad just ate a bearing after I did the head gaskets, timing chains and water pump. Ran great for about 2 months then no oil pressure and knock over 2k rpms. The oil is nice and glittery. Only had 123K on it so I didnt think Id need to touch the short block and the cylinder walls looked good. Oh well. Now I'm looking into just swapping in a v8. Once done, used VK56s are cheaper that VQ40s and easier to work on. Now I found a guy thats parting out a 2005 4x4 armada with a seized engine. I can take the ecu bcm keys ignition switch and engine wiring harness for cheap. Are the Armada parts the same as the titan parts when it comes to ecu bcm and wiring? Also does anyone know which pins have to be swapped on the harness? If I use the ecu and bcm with stock headers and hollowed out b-pipes do I still need to tune it? I plan on going with cajun headers and b-pipes later with a tune but Im on a tight budget and the xterra was my daily driver so the goal is to get it running again and make it cheaper to repair in the long run working on a vk vs the vq. Plus more torque is always nice and I really miss my old titan. But I love my xterra now more. Also does anyone know if the hill descent will still work after the swap? Any info will be greatly appreciated.
