Doesn't seem like there would be that much work involved.
That is where you'd be wrong....
You have to.... change the spring perch, new U bolt's, new custom length shocks, new custom length brake lines, new "one off" custom length ABS lines (that's the one that kills everyone and their truck). Secretly you really need new springs because the stock springs suck, probably need new shackles, then you need to have a custom double cardon DS made (Tom Woods doesn't do them anymore for us). That's the rear end....
Front end.... You'll have to do a bracket lift in order to achieve the height, custom length shocks, custom spindles that correct the TRE placement (if you don't you'll do nothing but blow up your steering rack over and over again). Going that high with the lift, you really need to t-swap, so add in LCA's, UCA's TRE's, CV's, and lets not forget the custom length brake lines, and one off custom length ABS lines.
And since we're talking about doing it right and having it work.....
The OP has a S and auto trans, meaning he's running 3.13 gears. If he's going to run larger tires, he's going to have to re-gear in order to not have things grenade. So now he's changing the rear axle to a M226, plus gears front and rear.
Adding things up in my head real quick.... that's about 20K or more... in parts.
