The F-Alpha platform is now being used by numerous vehicles and our differential choices have expanded from just R180 vs M205. While it is quite possible that the M205 is still the best option for front differentials, I think it is a good idea to at the very least document the other options, open peoples eyes and see where that information leads.
During my research, some things I have found quite interesting, for instance it looks as if the front differential from a Y62 patrol has an Iron case. Also, it looks like Nissan decided to cheap out in North America and put the R180 in front of the new Armada/QX80... it has 400ft/lb torque and nearly 5:1 first gear ratio.
Model: R180
Vehicles: 2005 - 2018 Nissan Frontier, 2005 - 2016 Xterra and 2005 - 2012 Pathfinder V8
Ring Gear Diameter: 180mm (7")
Gear Ratios: (Factory) 3.13, 3.36, 3.54, 3.69 (Aftermarket)
Carrier Types: (Factory) Open (Aftermarket) ARB Air Locker, Lunchbox
Spline Count: 27
Notes: Housing is very thin cast aluminum, subject to splitting under heavy loads in reverse.
Model: M205
Vehicles: 2004 - 2015 Nissan Titan, 2004 - 2015 Nissan Armada, 2004 - 2015 Nissan Pathfinder V8, 2004 - 2010 Infiniti QX56
Ring Gear Diameter: 205mm (8")
Gear Ratios: (Factory) 2.94, 3.36 (Aftermarket) 4.10, 4.56
Spline Count: 30
Notes: Housing is very thin cast aluminum, subject to splitting under heavy loads in reverse. The 2008+ "3 Rib" design is stronger, but still the case material is very thin.
Model: ??? (Nissan part number 38500-5ZW1A)
Vehicles: 2017 - 2018 Nissan Armada, 2011 - 2019 Infiniti QX56 & QX80
Ring Gear Diameter: ??? (Probably 180mm)
Spline Count: 27
Notes: Looks identical to R180, its probably a slightly newer R180
Model: MA235
Vehicles: 2016 - 2019 Nissan Titan
Ring Gear Diameter: 235mm (9.25")
Gear Ratios: (Factory) 3.36, 3.91
Spline Count: 33
Notes: Would Require Spindle/Hub swap
Model: 385001LB3A, 385001LB3B
Vehicles: 2010 - 2019? Nissan Patrol Y62
Carrier Types: (Factory) Open (Aftermarket) HARROP ELocker
Spline Count: 34
Notes: Cast Iron Housing
Model: R180
Spline Count: 27
Model: M205
Spline Count: 30
Spline Count: 27
Model: MA235
Spline Count: 33
Spline Count: 34
