21 - 40 of 48 Posts
nissan technet service bullitin re no heat
I'm a former GM service consultant and have seen my share of little known engineers service bulletins that you never hear about unless you dig in your heals or you get an honest service department or dealership that goes to bat for you. Northern Nissan in Sudbury On. is one of those that goes to bat for you! After 3 trips to the dealership and burping,vacuum testing and testing for pressure all results were within limits but my 2012 pro4x was still blowing cold if parked on a small downward slope or if left sitting at idle for a few minutes. Blair( dealership Manager)and Brian (fixed ops manger)had an all out war with Nissan Canada who finally conceeded that between a certain years and vin#s on the 4.0 litre Nissan engines that there is a bulletin describing warped heads due to defective metals that allow for air to seep back in and not be detected in a pressure test . The bottom line is they are replacing my engine with a brand new one. So if you have a newer 4.0 litre and have done all the things suggested to get airlocks out and you still have issues. Get on Nissan Canada's case!
Steve
Did they happen to give you the year range or VIN range? That'd be good info to share ...
Thanks for chiming in!
Another success, just low coolant.
I had bought some blue Nissan coolant before I checked the level just assuming that was the problem. After it came, I made the mistake of checking the reservoir with the X off and cold, where it sat at the MAX line. I then started to think I needed the Lesle no spill funnel to burp the system, but after coming across this I noticed that car should be on, and cold while checking the level. It dropped to be almost dead even with the min line, I filled it to the max, and BAM, full heat at idle.
Thanks!
Thanks!
Make sure you do it a few times. Always at cold start.
I did this over the holidays and filled to the MAX line 4 times. The 4th was just a tiny amount added, but still. The last couple times I've checked, it stayed at the MAX after starting. One top off might not be enough because the system "burps" itself.
So frustrated..my situation 2009 X, cold air at idle, heats up better when increase RPMs. Noticed low heat, followed instructions on this thread and topped off when cold and running. After, I noticed coolant leak, dripping from pan underneath X. My mechanic found leak from radiator and replaced. I made sure coolant was correct after the install by following the instructions on this thread again. Level was at max after running when cold. Very next day took a 3 hour trip, heater seemed fine on the round trip. The next day I checked level again when cold and running, still right at the max line. OK..thought everything was going to be OK at this point.
The next day, wife uses the X and says it never really heated up. I checked level again, and was still at max. I let X warm up and noticed it was blowing cold air until I revved it up, then it would blow warm. I took a drive and didn't heat up like it should and always blew colder when not stepping on the gas and blew hotter when accelerating.
So, this thread indicates no burping is needed, other threads discuss a burping process. I'm not sure what to do at this point. I checked radiator level and it's right to the top. Temp gauge is at about 4 o'clock when warm.(like it's always been). Reservoir tank at max line after checking cold and running. Any opinions? Would a bad heating element or t-stat cause this? It sure sounds like a low coolant level as described in this thread, but that does not appear to be the case.
Ok..can someone tell me where the bleeder screw is on my 09 X? The first pic is what I see under the hood, the 2nd pic is from another thread showing where the bleder screw is on 05-15s. Is it under a plastic housing? If not, then that 2nd pic is not the same as my 09.
The second pic looks like it is from a first gen Xterra?
That second pic is absolutely not a 4.0 vq, its the older first gen vg which is completely different.
I'm not aware of a bleeder valve on the 4.0. I "burped or bled my coolant system with a no leak funnel and about a few months later the bubbles in the dash are back. Im going to try the method in the first post here to remedy the bubbles. my heater does blow hot all the time once the truck is at operating temperature.
I am confident there is not a blown head gasket leaking exhaust gases into the coolant as it is very clean looking ( should see carbon in the coolant if exhaust gas is introduced).
Thanks!
Thankyou! I’m new to this forum and was having trouble with my Xterra heating (2015). Google search got me to this thread. I live in Colorado Springs and need heat. Had visions if $1000 plus bill for the car repair. Followed your very detailed and clear instuctions and now have HEAT, wonderful HEAT.... maybe better than when new! Thank you for you selfless diligent work... you are a godsend. Phil
I have been dealing with this not heat at idle issue for years, luckily now we don't drive the x everyday so its not that big of a deal butI'd like to get it fixed.
I have been through all the how to's, and replaced all the hoses I can get to as well as the degas tank and radiator. I've burped and topped up the system countless times but it doesn't seem to fix the issue.
All the hoses connected to the heater core are hot in the engine bay.
I've tried to flush the heater core, thinking maybe its plugged and only lets hot coolant through with higher revs. I can't find a diagram of the flow, I wanted to backflush it but I'm not sure I've done it the right direction.
I'm considering replacing the heater core, but don't want to put the effort into that and end up with the same issue. I have 2006 with just under 340,000KM. I dont have a coolant smell in the interior and I haven't noticed any dampness in the cab.
Any ideas? Am I wasting my time looking at the heater core itself?
Thanks for the help everyone this forum has been very useful over the years.
Just to be clear on this section of the notes:
1. Have a 50:50 mix of antifreeze and water available, at least 3 quarts. A funnel will help but isn’t necessary if you are able to pour into the small opening of the reservoir and the radiator. Ensure that the pressure relief cap is on the reservoir and the plain cap is on the radiator.
I need to swap the pressure relief cap from the radiator onto the reservoir, and place the cap from the reservoir onto the radiator? Then follow the rest of the steps?
Discussion starter · #39 ·
The pressure relief cap, the one with the spring, should always be on the reservoir and the plain cap should be on the radiator. Do not swap them. The cooling system is always circulating coolant through the reservoir to separate air from liquid coolant.
I had a customer vehicle that was blowing cold air but had no air pockets .
I removed both hoses from the core. I used a garden hose and flushed water both ways . Then I put two hoses on the heater core and filled it with a strong mix of CLR and water. I had both hose ends up high to not lose one drop of my mix. I let it soak for 30 minutes . I drained the mix into a pail and once done did the water flush again . Both ways . Once everything was put back together it had hot air blowing . Customer said it was the best heat since buying it used . Well here in northern Alberta at -40 we need a good heater
21 - 40 of 48 Posts
