Did my TS about a month ago and finally got to go out last weekend and do a shakedown run of sorts on a very light trail (was waiting to break-in the springs). As soon as I engaged 4WD we noticed a clicking sound coming from the front drivers side of the vehicle. Upon further investigation and discussing with HerbC and LIXterra I think we all concluded it’s most likely a CV joint going bad because of the angle caused by my 4” of lift.
I could just replace the CV joint, however, I would have to purchase an entire halfaxle and then tear it apart for the CV (new this would be $450 for the part, then $450 for labor). Second and more importantly, this would be a bandaid most likely because my setup has killed one CV already (in a month!) so just replacing the broken part wouldn’t really fix the cause of the problem.
So I’m leaning toward going to the M205 and swapping to Titan halfaxles. I didn’t do this in the first place because I intended only to go up to 33’s and so had no plans to regear, and I was only considering an ARB locker if I was already regearing an M205 which I had decided against. My understanding is that the halfaxles from the Titan handle the angle (above 3” of lift) better than the stock Xterra halfaxles, and that this alone should be a long term solution to this problem. Just checking, swapping to Titan halfaxles would not require me to get new wheels as the bolt spacing is the same?
At this point I could purchase and install parts for the M205 swap, then tear down the extended halfaxles that I have and sell them as parts (someone else may be in need of a OEM CV joint!). The extended halfshafts only have about 1k on them!
I also have one other possibly related or unrelated issue. While driving I will sometimes for just a moment get a sloppy feeling in the wheel or a light jerk on the wheel. This happens when driving around town on paved roads, seems to happen at any speed. I’ve checked to make sure all the bolts and nuts appear tight, including those on the tierods. Could this be caused by a bad CV, or just something that happens with bigger knobbier tires? It does not cause the car to lurch, but instead seems to only impact the steering wheel... Seems unrelated.
Below is the rest of the links for my sources (more for future readers that happen upon this thread) and at the bottom a list of parts to purchase for this swap if I go this route. If anyone see’s anything I missed, or has any other suggestions I’m all ears.
So to summarize:
1. Does this seem like a bad CV joint? Any other theories?
2. Agree that moving to the M205 and Titan halfaxles would reduce the likelyhood of wornout CV’s in the future?
3. Confirm that going to Titan halfaxles would not require changing wheels as the bolt pattern is the same?
4. Any idea about the cause of the steering wheel jerk?
Sources:
CV joints going bad make a clicking noise
http://www.thenewx.org/forum/showthread.php?t=50314
Aftermarket CV joints don’t have the same spline count as the OEM halfshaft, so they are not compatible.
http://www.thenewx.org/forum/showthread.php?t=61744
Want a M205 from 2008 or later Titan (3 rib)
http://www.thenewx.org/forum/showthread.php?t=24697&highlight=M205+differences
Regarding gearing, the 2012 Pro-4X Xterra has 3.357 (3.36) gears, Titan with Offroad or Tow package (or Pro-4X?) have 3.36 gears as well.
http://www.thenewx.org/forum/showthread.php?t=16360
Replace seals on both sides of diff if sourcing a used one (part included in list below)
http://www.thenewx.org/forum/showthread.php?t=46048
Parts list:
1x M205 (2008 or later, Tow or Offroad Package)
2x Titan half axles - 39100M
2x M205 Flange seals - 383428S110
Also need the following fasteners:
12x M205 Halfshaft flange bolts - 39606-17V0A
3x Diff/Frame bolts - 54726-7S000
2x Nuts for Diff/Frame bolts (1 screwed into frame) - 08918-3442A
8x Front driveshaft bolts - 37120-4P00A
8x Front driveshaft nuts - 37171-7S00A
So to summarize:
Sources:
Parts list:
