Ok I know enough to get me into trouble when it comes to wiring. I have a hitch mount winch system that I used to use on my last 4x4 but I only had it wired from the battery to the front hitch location. On the X I want to run it both in the front and rear locations, so for the Rear:
Question:
I obviously have to run power form the battery to the hook up location in the rear but I have to run a ground cable as well?
Assumption: No I don't. Just ground the winch to the frame and then upgrade/add a ground cable from the battery to the frame. Is this ok to use my frame as a ground cable or should I run full lenght all the way?
Question:
