How-to: Setup Euro Style Key/Remote Combo - PBR
22K views 48 replies 29 participants last post by  Old Navy
#1 · (Edited by Moderator)
Ok, the route I went, was to buy the new Key Combo Shell. It didn't come with the Buttons for the remote or the Battery or anything. It just came with the actual Key Combo Unit with an Uncut Key, and a Transponder Chip that needs to be Programmed. I had to do a lot of trial and error, thus I wasn't able to get all of the pics that I wanted to for this. It is now screwed together and it comes with a nice Chrome Nissan Emblem for the back side that covers up one of the screw holes. so, needless to say, I didn't get the pics of it apart, but let's be honest, if you don't know how to take apart a Key Fob and put the guts into another, you probably shouldn't be doing any Do-It-Yourself work.
Okay, Step One; is the obvious of removing the guts of your current Key Fob and putting them into the new unit. Besides just taking out the Battery, you will also need to take out the little Metal Contact under the Battery. You need to be able to complete the Circuit in the new unit, so make sure you pay close attention to how it was sitting in the Stock Unit and how the Battery sits in it. Put it in the exact same spot in the new unit. Before the new unit is put back together, you need to put a Transponder Chip in the little slot that is provided at the top next to where the Actual Key Portion is. I used a little RTV Silicone, so it would stay secure in there, otherwise it was coming loose and just being a loose piece in the unit.
Now, you could use the Un-programmed Chip that came with the new unit, but that Costs $45 at the dealer to have programmed. Instead, I took apart my Valet Key to get the already Programmed Chip out of there. If you look at the Key where the Blade Connects to the Body you will notice a little Square Line where it looks like it is a piece that comes out. I used a very small Flathead Screwdriver to pry this piece out. It is a little tray that holds the Transponder Chip. Just remove it and use it in the new unit.
You will next have to put the Key Blade and the Button/Spring Assembly back in its Notch before you screw the 2 Body Pieces back together, but make sure that you wind the Key around so it has tension. Otherwise you will have a 'Bad Ass New Unit' that doesn't Spring the Key out for you.
Next screw the pieces together and make sure that the Buttons work. The Frame of the new unit wasn't made exactly to fit like the Stock Unit, but it works. Just make sure that the Buttons are working, so you know if you need to take it apart again. After that, take the unit to the dealer and have it cut. I tried going to Lowe's, AutoZone and many other Key Cutting establishments, but was turned away because their machines don't cut any newer Car Keys. One guy told me that the Car Manufacturers made them a certain length to where only the dealer can cut it. Now, you may need to argue with the guy for a minute, because once he sees the Unit, he may not believe that it will work for a Nissan or that it is already Programmed, so you may have to break it down slowly in Kindergarten Terms like i did. After that Voila. Make sure everything works one last time and make sure the screws are tight, and stick that Chrome Nissan Emblem on and enjoy how much easier and cooler it is to have this new unit that only cost around $30 in the end. This is my first 'How-to' so I wouldn't mind any feedback.
#4 ·
This is great! I really like the idea of combining my key and fob together for some less bulk in my pocket.
Good write-up for a first time...just wish there had been more pics taken. Thanks for putting this up.
#5 ·
okay so when you put everything together...the insides of the remote do not fully take up all the space around the button area like they should right?
cause i went the same route as you did just ordering the empty key fob and tried to put the guts of my key fob in and it looked like crap because it didn't fill the new key fob up...
#6 ·
yeah, it didn't fill all the way around on the inside, but once i got everything in just right and screwed it together, it stayed snug. the only thing i didn't like at first was that the buttons are angled and rounded instead of being flush with the surface of the key fob, but after a few days i didn't care anymore. with how convenient and easy this new key combo is, i don't care how it looks...(even though it looks great)
#8 ·
ARISE, chicken chicken!!! ARISE, chicken chicken!!!
thread necromanced.
case ordered for $12.98 shipped. I'll follow up on here w/ more pics to fill in what Coins said he was missing.
#10 · (Edited)
yeah, i did it, and failed at taking pics. it works great
ps, i took the uncut key out of the case and to home depot and they cut it for me for FREE.
the lady was surprised that it would work, but it did....like a champ!
#12 ·
#14 ·
yep, its pretty self explanatory once you get it opened up. you just swap out the guts and the rubber buttons. i stuffed a piece of cardboard next to the security chip to keep it from rattling around
#17 ·
also available on ebay, just more expensive. or you could just buy another fob and use the new buttons.
#19 ·
Finally did this last week...love it!
I just had a b*tch of a time getting the metal battery bracket thing to work correctly. Took some finagling for about an hour+ to get all the contacts to line up right on the circuit board.
#27 ·
FYI this took 2-3 weeks to ship from China... well worth it, but don't count on it for an upcoming weekend project. challenging part for me was getting the bottom chrome key ring to fit in, took almost an extra 3 minutes of tinkering :)
#29 · (Edited)
I just got mine cut at Depot, aaaand now realizing my key is the same w/o the chip tray. Has anyone done this mod with a 2009 or newer...wondering if it's embedded into the key handle instead of in a tray?
BTW - at HD, the key cartridge they use is #38, they had to try a few different templates before finding the correct one
