Claw X: 37's/4.56's/ARB's
162K views 617 replies 71 participants last post by  XterraTSP4
#1 · (Edited)
Work in progress! Definitely open to contructive comments!
Make:
Nissan
Year: 2011
Model:❌terra
Trim: Hybrid
Color: Stormtrooper White
AUGUST 2015 - Truck of the Month
2011 Nissan Xterra:
Purchased October 2011
Currently: (As of Dec, 2015)
Milleage: 53,xxx
(Front)
-TS Radflo coilovers w/Resi May2014
-OEM Titan LCA's March2013
-PRG Titan UCA's March2013
-PRG titanswap Heim Billet Steering March2013
-PRG Extended SS 25" Brake Lines Dec2014
-PRG 1/2" Top Plate Spacer Dec2014
(Rear)
-Alcan 4.5" Lift Pack w/450lb June2014
-Nisstec 4* Shims March2015
-Radflo w/Resi Rear Shocks May2014
-PRG U-Bolt Flip Kit w/bash plates March2013
-PRG 2" Shackles March2013
-PRG Extended Rear brake lines Dec2014
-Nisstec 2" Extended bump stops March2015
Drivetrain:
-M205 w/Arb Locker & 4.56 gearing Dec2014
-Royal Purple Diff fluid 75w-140
-M226w/Arb Locker & 4.56 gearing Dec2014
-MagHytec gasket Dec2014
-Ballistic Fab diff cover Dec2014
-M205 titan axle shafts Dec2014
Tire/Wheels/Brakes:
-(4) Maxxis Trepador M/t 37x12.50r17 Feb2015
-(1) Goodyear Mt/r 37x12.50r17-spare Feb2015
-(5) 17x8 Level 8 MK6 Wheels May2014
-Balancing Beads Feb2015
-Heavy duty Valve Stems March215
-(24) Black Gorrilla Lug nuts May2014
-Brembo Front & Rear Rotors Feb2015
-Stillen HP Matrix Front & Rear Pads Feb2015
-Custom Front Tube Bumper(Line-X'd) May2014
-B.A.M.F. Rock Sliders W/ Kickout Jan2013
-Hefty Radiator Skid July2014
-Hefty Engine Skid July2014
-Hefty Trans Skid July2014
-Hefty Transfer Case Skid July2014
-Hefty Gas Tank Skid July2014
-InSainFab Rear bumper w/Tire Carrier & Hi-Lift Mount May2014
-InSainFab Rear aluminum hi-clearance bumper corners Sept2014
-InSainFab Rear Shock skids Dec2014
-20" Totron Dual Row Led Bar Feb2015
-(2) 3" Totron Square Led Feb2015
-DDM 6k HID's Nov2011
-5% Window Tint Nov2011
-Cravenspeed Stubby Antenna Nov2011
-Engo 10,000lbs Winch w/synthetic line March2013
-60inch Hi-Lift
-GPAX Bottle Opener (Mounted)
Performance:
-(12740) Volant Cold Air Intake March2013
-Airflow Snorkel w/adapter for Intake April2015
-AFe Throttle Body Spacer July2012
-DT Cat Delete "B" Pipes July2014
-Custom Flowmaster Exhaust System Jan2012
-PRG Motor Mounts Dec2014
-BullyDogGT Tuner Aug2014
-CSF Aluminum Radiator Sept2015
-Kenwood Double-Din InDash March2012
-Kenwood 6.5 Speakers March2012
-Kenwood Amplifier March2012
-Uniden PRO505XL 40-Channel CB Radio April2013
-Firestik 2' Firestik Ii Fs White Antenna Feb2015
-Firestik SS-3H Heavy Duty Stainless Steel Antenna Spring April2013
-FireStik K-8A 18ft Coax Cable April2013
-FireStik SS-204A Adj SS vertical door jamb mount April2013
-Weathertech floormats April2014
Gear:
-Set of Aluminum Tire Deflators March2013
-(171302) ARB Tire Inflation Kit May2013
-(ARB6050 ARB Tire Inflator Gauge May2013
-(CKMA12) ARB OnBoard Air Compressor May2013
-Trasharoo Spare Tire Trash Bag Aug2013
-Rangler Dog Net Divider Aug2013
-ProLink Loaded Shackle Winch Mount (Blue) May2014
-Anodized Alluminum Fairlead (Silver) May2014
Mods to come/Wish list:
-Radflo/King Bump Stops Front & Rear
-Arb 63qt Fridge/Freezer
-Dynomat sound deadening doors, ceiling, floor
-LineX rocker panels and Inside of roof
-Ham Radio
-Lowrance GPS
-JL Audio 10w7 Subwoofer
Gone Moab 2015 - The Drop on Steel Bender Trail
Top Less and on 35's
Just letting my dad drive as i am watching on Fins N' Things our last day in MOAB.
Dec 2015 wheeling Pillsbury
#7 ·
I like it a lot, it definitely makes a difference paired with my intake, throttle body spacer and exhaust. I will notice more once i can buy headers, intake manifold spacer and rear cat deletes. But i def recommend getting it.
nice rig!
Thank you!
#18 ·
Thanks a lot. Yea i like them. They are just really heavy for a 285/75/16. The toyos havent let me down yet tho. Anywhere from mud, snow, ice or gripping the asphalt through turns lol I have thought about going a 33/12.5 nitto mud grappler or a 295/75/16(34") hankook m/t once my titan swap is finished.
#26 ·
Haha thanks and yes we should talk. I have a few buddys who have hit up Rubicon in their Yotas and Land cruisers. We could prob do a sweet summer trip!!
The rear end is not locked yet. I had some trouble with my extended axles in the front. So i actually do not have them installed at the moment so no 4wd. After i get my front axles sorted out, i will then start saving up for OBA, F&R air lockers, body lift, and a few performance mods. No money!! lol Due to TS and kitchen renovations.....
Nice rig, it's coming along quite fast :)
TS looks good!
Quick questions for you:
When did you get the SAWs? And when did you place your order? Did you get the Ext. Rez SAWs?
Thank You very much. Its slowly coming along. I have had the X since Oct 2011 and the only mistakes that i have realized are that i should of titan swapped from the beginning and should have spent the extra couple thousand $'s for a manual Offroad Pro4X. I purchased my parts slowly a long time ago. Just took a long time to install. They are not Ex Resi...Internal Resi! :)
Nice rig. Never realized how far the titan swap brings the tires out good lord ! What you have to run 2"+ spacers in the rear now ?
Thanks. Its a struggle right now. I still need to adjust my heim steering and install the cam bolts. The steering wheel is slightly not centered lol and i want a little more camber once i get it aligned. The titan swap is i believe 2" wider per side plus i am running 9" wide wheels, 12.5" wide tires and 1.5" wheel spacers front and rear! I still need to trim the front fenders in the front. Hopefully its not raining tomorrow morning so i can do it. I need to sell the rear 1.5" spacers and install 2" spacers. You prob didn't notice the tires out because many people just run stock wheels with 285's.
#33 ·
Yea I can take some pictures. Bay Area Metal Fabrication (BAMF) currently does not make sliders for the Xterra. What I did was I purchased the 2nd Generation Regular Cab Tacoma Sliders with kickout. I need to contact BAMF so I can return and have them measure the X because the front mount on both sides are very close to the body mounts. Let me know if u have anymore questions about them.
#35 ·
I don't mind at all if u take the style. I had these on my Tacoma and I like the kickout because I use it as a step for my snow racks and helps push away from rocks and trees which is great! Yea I love the bumper. It's lighter than pretty much all aftermarket bumpers and I like the tube style even though I wish a company made a hybrid bumper like All-pro offroad makes for Tacomas. But o well I'm happy with it.
#36 ·
Why keep the 1.5" spacers on the front with the t-swap? The tswap already pushes the wheels out 3 inches on each side.
I mean I love the stance and I love my stance on my truck with rims and the swap. I actually even plan on going further out when I dump the titan swap and put a titan mid-travel kit up front with a 1 ton in the rear but I don't see your need to keep the spacers on up front.
#37 ·
I like look of it with the 1.5" spacers up front. Also with these wheels to clear the brake caliper I need to use a spacer or I need to grind down the caliper so there isn't any rubbing. I would like to do a Titan mud-travel kit or SAS eventually once the X is paid off. I just like the wide stance also!
