1 - 10 of 10 Posts
1st, yes, I used the search feature. Didn't find anything that really described whats going on with my X.
My problem:
Installed my 2" spacer lift this past weekend. Now I get a clunk noise from the front. Can't tell if its right or left side. It only happens when I am turning around in my driveway, doing less than 5mph with wheels full lock either direction. I've 3x checked torque on everything I had apart(shock bolts, swaybar, etc). Any thoughts?
Discussion Starter #6
Found a ton of movement in the rotors today. Appointment at stealership for Tuesday. Gonna have the wheel bearings looked at.
Sent from the bunker on the hill
Without the wheel on you will have movement in the rotors until the rotors rust onto the hubs. :eek:ccasion5:
1 - 10 of 10 Posts
