Did anyone who lifted the front of therev 05- 06 X purcahse those Camber bolts,etc fro CALAMARI??I Added my 2"spacers and dosent FEEL out but...And havent had alighnment yet..
With the 2" spacers, you will need an alignment but as long as you have the stock cam bolts installed, the alignment place shouldn't have a problem getting the front end into spec.
You should have adjustable camber bolts from the factory, if not there is a service bulletin about it. The dealer should replace your non-adjustable ones for free.
If you look at the camber bolts you should see little tick marks around the washer looking thing under the bolt. I think the non-adjustable bolts are concentric too, the adjustable ones are not.
