1 - 20 of 41 Posts
Username: Xtracrispy
Old X, sold but not forgotten.
Year: 2005
Model: Xterra 4x4
Trim: S - MT
Color: Silver Lightning
Suspension/ Tires/Driveline:
-265/75-16 Definity at2.
-Radflo 2.5 oe length coilovers 600lb springs
-"Franken-Pack":
PRG 2 leaf AAL(long leaf only) + Nisstec AAL
-Fox 2.0 rear shocks
-Custom rear drive shaft w/1350 rear U-joint.
Exterior and Armor
-HeftyFabworks Sliders w/ steps, bedlined
-HeftyFabworks Radiator, Engine, and T-case skids.
-OR gas tank skid.
-Relocated trailer plug into rear bumper from hitch.
-Rear diff breather mod
-BTF Kryptonite diff cover
Recovery Gear/Other Goodies
-Warn M8000 "hidden" in front bumper
-Recovery hitch/shackle
-Assorted recovery gear, straps, pully block, etc.
-Folding Shovel and Jumper cables.
-Trauma bag
-Murano 14" rear wiper.
Interior/Electrical
-Kenwood head unit, Kenwood amp and RF 12" sub.
-Midland CB
-3' Firestik II mounted with Firestik jamb mount kit.
-Optima Red Top
-McMaster 150# hatch struts
-12" LED lightbar, mounted on winch fairlead.
Removed
-Stock steps
-Mudflaps
Comments: 170,5XX miles and still kicking when it was sold.
Skids:
nice! clean looking rig. can't wait to see what you have in store for her! Modding is an addiction and owning an X is a lifestyle! Owning my Xterra has changed my life completely! enjoy!
Discussion Starter · #7 · (Edited)
Thanks.
Next plan it to get OME front shocks and spring (feel like they might be a better choice for me than Radflo's) and thinking about a winch in the stock bumper, and maybe some driving lights. Want to get the full OME kit and/or a winch bumper, but can't really afford it all right now.
Discussion Starter · #10 ·
I took a slightly different approach than most. And while it might not be the strongest option, I think it will be sufficient for my needs.
Basically, I got a universal winch mounting plate and welded it to the stock bumper. The mount took some trimming to make it fit. I believe this setup will be adequately strong, and the absence of recovery points on the bumper will reduce stress in 2:1 pulls as I will be using the OEM tow hook.
Not the best pictures but you can get the idea. I also liked the idea of mounting the winch higher to keep it out of harms way, and any water/muck I may encounter.
Like I said, I'm sure its not the best option, but I think It will work fine for me. If I begin to have problems, it would be easy to reenforce if needed. I only foresee 2 potential weak points, the frame mounts and the front mount area where the fairlead mounts(some steel angle would easily fix both those problems). I will gladly deal with those at a later date if I think I will have problems though.
If you have any questions I will gladly answer them.
Discussion Starter · #16 ·
Installed the locker and diff cover today. Hooks up awesome in the dirt. Have lots of pics.
Cover ended up a little more "chrome" than I thought.
http://s158.photobucket.com/albums/t84/Desertrunner07/Xterra/
Images are in reverse order, ones in the end came first.
Has some quirks on road, hopefully it will break in/ I will get used to it. Most roads can't feel it much, at parking lot speeds acts up a little, need to get used to the best clutch/throttle use to keep it smooth.
Discussion Starter · #18 ·
How do u like that spartan locker? I like your different than most style. I'm not going to do a winch install like yours.
Still too soon to give a good review on the locker. Has some quirks but it seems(and I have heard) you can get used to adjusting your driving style. I think since I'm a manual its a little more tricky to keep it smooth. Most of the time can't notice it too much, but in slow and/or tight corners(parking lots) it kinda makes the truck "buck" if it's not under much load, again I think worse since I'm a manual transmission.
Well if the sand and softer dirt areas you will shimmy a little bit when it engages but I think you can adjust it some to try and not bind or buck on the concrete unless you slip
Discussion Starter · #20 ·
I've also heard these lockers like Mobil 1 75-140 gear oil. I'm using 80-90 since thats what I had on hand, so I might change the oil out sometime once I get some miles on the locker.
1 - 20 of 41 Posts
