1 - 7 of 7 Posts
Looking for some help on part numbers to change just the U-Join cross from the driveshaft. Please help I am in Denver Metro Area.
Thanks
Try looking at a parts search by vehicle function on major online retailers.
Amazon for instance has the below results for your 2004, but confirm your configuration. (Spicer is a decent brand btw and they have with or without grease fittings available)
https://www.amazon.com/s/ref=sr_nr_n_10?fst=as:off&rh=n:15684181,n:!15690151,n:15719731,n:15723911,n:15724841&bbn=15723911&ie=UTF8&qid=1519940702&vehicle=2004-67-901-49--9-9-7--1743-9-2-2249-18-1-0&rnid=15723911
Your factory service manual can be found here for free: Nissan Xterra Factory Service Manuals
And local auto stores (Advance Auto, etc.) will loan out u-joint bearing press tools too for a DIY project. I recommend obtaining an impact wrench and/or 24" breaker bar to get your DIY driveshaft U-Joint project underway.
Thanks
If you are on Facebook, contact the NORAC group. You'll find 1st and 2nd gen people there and who to contact at various Nissan dealerships.
Moved this question to the on-site NORAC Thread so the members could answer his question directly.
TNX Senior Member / (NORAC) Club Moderator
Your best result will to go to the NORAC4X4 facebook page and ask the question there. NORAC has only a couple 1st Gen members, but you probably get a good answer there.
NORAC will help, but join Xterra Crew and NISSAN Xterra facebook groups and you'll find a ton of 1st geners who can help.
Also clubxterra is the generic allgen version of this site.
1 - 7 of 7 Posts
