1 - 20 of 49 Posts
Intro Comments: Been a member of the forum for many years, but haven’t been active since I trading my 2012 Xterra in on a 2dr JK.... I know, I know.... I knew as I was driving home from the dealership that I had made a big mistake. Fast forward 3 years and I’m remarried and now have 2 daughters and 2 step daughters.... The Jeep isn’t cutting it anymore, (plus there is ALWAYS something wrong with it), I missed my Xterra, but I need something that will seat 6. It took 6 months to find one rust free with low miles and It was 1400 miles away plus I over paid for it! but finally I found a 2011 V8 Pathfinder.
Ok so this isn’t an Xterra, it’s more like its bigger brother. But from the driver seat you can’t really tell the difference, except for that V8 5.6L under the hood!
This has to be a “ Be All - Do All” Truck! There is going to be a LOT of custom parts, but I will also use as many OE parts as possible to make getting replacements easier.
Username: ori
Year: 2011
Model: Pathfinder
Trim: LE 5AT V8 5.6L
Color: Dark Slate
Front Bumper - custom
Rear Bumper - custom
Sliders - custom
Skid Plates - custom
Drivetrain:
>Front
M205
ARB
4.10s
>Rear
JK D44 retubed to 70” WMS to WMS with 35 Spline Shafts
OX locker
4.10s
>Front
Titan-swap with King Coil Overs
>Rear:
Custom 4 Link SAS
Rims/Tires:
17” KMC enduro beadlocks
37” Cooper STT PROs
Future Mods:
Details to come... Plans could change some depending on hang ups... You know how these things go. :D
This is what it looks like right now.
Discussion Starter #7 (Edited)
Xpedition Path build
Due to time constraints and the number of projects I’m currently working on, I’m making a few changes. Going to stay with the M205 and do a Titan swap with king coilovers in the front. I still plan to build the custom IFS setup but it’s getting pushed back a while. I’m ready to get this thing on the trails!!
NewX’er 4life
You can also slap on the rear end of an armada to match the front titan swap. Then re-gear both to match.That will give you 8” of travel front and whatever the extra travel the armada gives in rear (if you stay OEM) saving thousands, or if you want aftermarket titan arms up front 10” of travel. If I had a V8 pathy that’s what I’d do anyway.
Discussion Starter #10
All of my parts have finally arrived!!! I’ll tear it down next weekend! Got the CB installed this weekend. Also covered up the wood grain on the center console. Still need to mount the antenna and connect the hot wire but the hard part is over!
Before
After
Please excuse the dirty truck...
Also still need to wrap the wood pieces in the door panels.
Discussion Starter #12
I’ve made a little progress. I’ve got the front mocked up. Still need to build upper control arms and coilover mounts. Also got the rear 4link brackets welded into place and some temporary links to check clearance on a few things.
This build is BadA$$. Looking forward to seeing your progressions. Sub'd
  • Like
Reactions: ori
1 - 20 of 49 Posts
