Hey Folks,
I found a Pioneer "Premier" HU on the web at a much better price than "Slutchfield". I bought the Pioneer XM tuner from them though as well as the wiring kit for the "06 xterra.
I originally got this stuff for my "04 diesel Jetta that I traded for my X.
Well, the HU bolted in perfectly like it was made for the X, but I still needed to mount the xm tuner box.
What I did...
If you pull the panel underneath the steering wheel, just above your feet, you have to peel back some door trim on the driver's side to find the other screw on the left side. You will find an angle steel cross bar held in with two 10mm bolts. Take this out drill two holes in the top and mount the xm tuner on it w/some foam underneath, you can run the wires right up through to the radio behind the dash. I stuck the antenna in the front of the dash between the dfroster vents, reception kind of sucks there so I will eventually have to relocate it to the roof. But the install is clean and fuctions perfectly.
I think the Pioneer xm box is much better quality than the Terk units, and it plugs directly into a Pioneer HU, which fits in an xterra like it was made for it.
Now , can someone explain how to post pictures? If you folks are interested...
fastbrake
What I did...
fastbrake
