1 - 9 of 9 Posts
I'm in Western PA, Cranberry. I put a PRG lift on (the spacer) and now I have +2 degree camber. I need to get that rectified ASAP.
Got bolts?
I might have an extra set, but probably not for a week or so. I have to pull mine to bend some metal back into shape. I have an extra set incase the ones I pull out are messed up. If they are not messed up, I'll have two sets.
Don't forget I wouldn't mind getting my hands on that spare set, Muzik.
I forgot. :) I think we worked something out, so I'll probably still have a spare set. Again, it depends on what the ones look like that are currently in my X.
You might need the bolts, you might not. Only the alignment guys can really tell once they put it on the rack.
Camber is that makes the tires look like this. /-\ or \-/ instead of |-| when looking at the vehicle from the front.
1 - 9 of 9 Posts
