1 - 8 of 8 Posts
Where are you located? I have an entire c200 3.13 axle you can have, just come get it. I’m in Western Mass.
Central PA unfortunately, but I really appreciate the offer. If there is anyway you would be able to come up with a number for the R&P 3.13 is what I need, also the flange. I'd be willing to pay for your time to remove and ship to me.
Ok. I’ll see what I can do to pull it apart.
I’m assuming the flange you need is the one at the pinion to the driveshaft. Is yours 6 bolts or 4? I’ll look today to see what’s on the one I have.
Mine is a 6 bolt flange.
I’m not actually sure if the X ever had a 4 bolt flange. My former Frontier could have either had 4 or 6 bolts, with no real rhyme or reason.
Discussion Starter #6
Thanks for getting back to me, I have a 4 bolt Flange but I can probably reman it to get it to work fine with some thread work
Discussion Starter #8
Bad pinion bearing trashed the R&P in the rear end. I ended up having to just buy a whole rear for crazy money that was half junk :(
Thanks anyways guys
1 - 8 of 8 Posts
