hi,
take a look at these wheels i found.
http://underbid.com/cgi-bin/underbid/underbid.cgi?action=display&item=94399&seller=Motorweb
would these work with a 1 inch/25 mm spacer from here:
http://www.ezaccessory.com/Wheel_Adapter_6_Lug_4_5_To_6_Lug_5_5_p/6450-6550.htm
I know these spacers will change the lug pattern to where the wheel will FIT. but will it be to far outward???
what is the offset of the stock OEM wheels for comparison?
it says that these RAZOR wheels are 16x8 with 6mm offset. with a 25 mm spacer that would make it -19 offset, CORRECT??
also, you can see a really good up close picture of these wheels on www.discounttire.com by searching 6x5.5 lug pattern with 8 inch width.
thanks,
Jason
thanks,
Jason
