Keeping in mind that no matter which setup I go with, I only want the same amount of lift that I am currently getting with the Top Gunz Spacers, appx. 2.25". Is it worth going with the TC UCA's and the Radflo's vs. just getting the shorter Radflo's. If I go with the longer Radflo's and the new UCA will I be able to get more downward travel (or at least an amount that would somewhat justify the cost) as compared to the shorter or is it limited by the UCA and coil bucket at some point either way? Would the ride be better having the longer shock dialed down like that? I do not desire to get any more lift than I currently have because then I would have to get larger tires to fill the empty space and besides that my girlfriend is short and has a hard time getting in as is.
