1 - 3 of 3 Posts
Would a OEM RF 6 disc head unit plug and play in my non RF equipped "S"? I am considering this because I would like to retain factory look (theft deterence) but be able to have capability to play MP3 and multi discs. I would probably end up hooking up an aftermarket amp and some decent components for the front.
From what I've heard, it's non-amplified so you do have to have an amp for it to work. Sounds like you have that covered so I'm sure it will work fine!
Won't work !
the brackets are different and the wiring harness isn't under the seat for the rest of the system.
I was able to connect But, without the amp the stock unit is better.
So, I have a spare R/F head unit Too !
1 - 3 of 3 Posts
