1 - 12 of 12 Posts
Hi, so I've bought some Hella 500 driving lamps and I have them mostly wired in but the instructions say to splice them into the high beams. Is there a way to circumvent this step? I want my driving lamps to be completely independant of my stock headlights. Thanks!
Search VMAN in the How To for his write up. It helped me a lot when I wired my lights.
i wired mine off the power wire from the turn signal lights.....they can only come on if the auxiliary lights are on and i have them on a switch also so they don't come on unless the aux lights are on and the switch is on.
That's what I did and i think it's a smart move. Chances of leaving them on by accident would be lower and how often would you use the Hella's without your marker lights.
What color is the wire you spliced into in the parking light harness. There are three, red,green and black.
Good question, I don't remember. I know I tapped in with a vampire tap right behind the light. I tested the circuit and found the + lead. I will assume that was the red one.
I installed my hella lights the other day and tapped into my parking lights. The red wire is the one you want to tap into. It only lets you turn the lights on when the parking lights or head lights are on. No way to leave them on by mistake.
i just tapped the return power fro the 12v plug in the center console since i mounted my switches on the face of the console. this way the lights wont turn on unless the key is turned to acc
i tapped mine to a constant 12v, so i can turn them on weather the truck is on or off.......
i thought about doing that originally, but my knee tends to hit the switches, so i'm glad i did the turn signal...i've drained a few batteries by leaving things on accidentally.
1 - 12 of 12 Posts
