1 - 6 of 6 Posts
so today my left side headlight went out,
like is not out all the way it has that amber lookin light
and mi right side is on
but the other day my right side went out and mi left side was good
now they were bnoth good
and today when i turned it on mi left side is bad and mi right side is goood
so i was deciding can i just upgrade the wiring harness or a Wiring Harness Plug and Play
im running Nokya 9007 yellow bulbs
and these are the nokya wiring harness...
thanks
there is the link for the wiring harness
http://www.nokyausa.com/wh/9103.html
here is the link for the wiring harness plug and play
http://www.nokyausa.com/whpp/9114.html
If the wattage is higher than the stocker's 55/65 then you're running the risk of burning out your wires. Mine did it twice, the first I replaced the harness ($60 bucks from the dealer), the second time, I just went back to stock wattage requirements and all is good. Check by moving the headlight connector. If your lights dim/go out then it's your wiring.
Discussion Starter #4
it was only 60 bucks
they said it would cost me like a arm and a leg
to replace my whole wiring set
k1w1t1m said:
You might check and clean all the grounds
wat do u mean by this
I should mention that I was told that Nissan wired the whole truck on one circuit. What I ended up doing is buying just the part that connects to the lights and splicing it to the main harness. If you go this route might as well but wiring that can handle higher loads. I believe Hella has a kit.
1 - 6 of 6 Posts
