Wiring lights?
Roof and bumper lights.Wiring lights?
Thanks again for this great thread...been studying/referencing in preparation of wiring my bumper/roof mounted off road lights.Thank you, and to answer some questions;
#2, personally, I go to futureshop or best buy and wander into the stereo installation bay and ask them to buy some lengths of wiring. Every time, they just give me a bunch of extra wiring they have laying around for free. And it's not crap either, my entire truck is wired with Monster cable that I got for free.
All my lights are wired directly to the battery (through a relay!) so that I can turn them on without the key. I wired them like this on purpose, and no, they will not kill your battery if they are turned off.quick question guys, any problems wiring PIAA offroad lights to the battery and having it always 'hot'? meaning the lights can be turned on and off even without a key in the ignition. i am not sure if this is a good idea since the piaa switch has an on/off light that will always stay lit, will that eventually kill the battery?
thanks. yeah thats how i had it set up. but piaa switches have a green led light on them. that stayed on all the time. concern was led light going out or causing minor drain. like problem here:All my lights are wired directly to the battery (through a relay!) so that I can turn them on without the key. I wired them like this on purpose, and no, they will not kill your battery if they are turned off.
This is how my lights are wired:
When the lights are switched off, there's no voltage flowing, so it can't kill my battery...
That is awesome! I know jack about electrical crap, and now, Im not as terrified! Thanks! Ive seen other electrical info threads, but this is great for someone who likes instructions drawn out in crayons!
Depends on what you're hooking up to it I guess. It says it's rated for 25 amps so be aware of that.Going off the diagram, I'm about to order this for my footwell breaker box:
http://www.amazon.ca/gp/product/B00CFFR8DU?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A3BF1KM87HNCSG
Just wondering if that's good enough to hook up the 4ga wire on it, any thoughts?
awww I didn't see that 25amp.... although it's saying 25amp/way which should be good enough for me. Right now the only thing that will be hooked up is my front led lights but I'm trying to think ahead where a 40" roof light bar will be on that and maybe a couple additional front lights but nothing majorDepends on what you're hooking up to it I guess. It says it's rated for 25 amps so be aware of that.
Thanks! Power comes from the fusebox but only powers on the relay, so there is very little current going through it. The relay powers the lights and handles the high current. This makes things safer for the switch and its wiring, and prevents switches from sparking and overheating because they're usually not designed for high current to run through them.Nice job bro! I have one question... whet are your toggle switches pulling power from? Don't the switches pull power from a 12v source like cig lighter or an add a fuse? The diagram shows them on the same source that is supplying the lights with power? Sorry if this is a novice question, I'm new at this. Again, much appreciated write up.
