1 - 8 of 8 Posts
Subject says it all....
Yes, I too am suffering from a bit of 'front diff paranoia'...mine is a brand spankin' new '07 OR and I know they went to the 4-spider rears, but have no idea if they've made any changes to the front....
For the record, I did use the search function, and couldn't find any explicit references this to save my life.
Thanks!
well, the great thing about a spacer lift is that if anything does break you can take out the spacers in about 15 minutes... the dealer never has to know they were there.
calmini
Nissan dealerships will install calmini 2.5" spacer and shackles lift for $650!
Spacers are so easy to install a caveman could do it! No lube necissary!!
And NO they wont void your warranty, now if you get larger tires to stuff under your truck then that could possibly be a reason the dealer will use to void your warranty.
so i just priced the calmini spacers and shackle kit, it would be like 175.00 plus 55$ or so is that right? also, what are the caveats of installing this? and do i get 2.5 inches in front and 1.5 in the rear? would that look/act normal??
is that all i need? also, is it pretty straight forward to install the spacers and the shackle kit???
thanks..
1 - 8 of 8 Posts
