Sorry if this is a repeat, I tried to find any postings on this this subject of 18 and 20 inch wheels and tires.
Thank you in advance for any help you can send my way. My question is, is there any reason you can't run the following setups, after a 3" lift on an 08 Xterra OR?
The 285/55R-20, tire & wheel combination is only .69 taller, and .79 inches wider than stock on an OR.
The 285/65R-18, is also only .94 taller, and .79 wider than stock on an OR.
If you compare that to a 285/75R-16, which is 1.18 taller, and .79 wider than the stock wheel on an OR.
Is there something I'm missing, as to why you could not run a 20" or 18" wheel and tire combination? Would it have anything to do with the rim being 8.5" wide?
Again, thanks.
Matthew
Again, thanks.
Matthew
