2006 Off Road 187,500 miles. Suddenly my oil is disappearing,... sort of.
I'm losing about 3 quarts every 10 days. I check more often but that's the easiest measurement.
Background:
Oil Pressure Sending Unit/Switch Gauge went bad in April. Replaced it and for the first time it is actually fluctuating with RPM when at standstill. Don't remember it ever doing this before but love the fact that it is actually a live guage and not a dummy.
After Gauge repaired I also changed:
CAM Position Sensors CPS0005 & CPS0008
PCV Valve PCV2390
I say oil is disappearing because the engine bay shows absolutely no sign of an oil leak. Nothing on garage floor, park it in same spot 7 days a week and nothing.
That being said, I am sputtering carbon/oil out of my tail pipe. Every time I start her up i get a light "dusting/patch" of carbon or oil residue (see pics):
Please help. What is causing this and what's the fix.
I should say that she has never run better. I drive about 55-70 miles per day at 75-80mph and she drives smooth as can be. I am amazed at 187,000+ miles she runs like a dream. Starts right up, idles beautifully, cruises along like shes brand new. No lights on, oil gauge works flawlessly.
I would appreciate any help here. I have been a long time member and have fixed hundreds of issues with the resources provided by our members and I am grateful that I never, until now, have needed to ask a direct question. It's always said that "Search" is your friend and it has served me well. This one is too specific and I would appreciate the community's input to help me solve this. I love my rig and have no intention of letting her go.
I just keep topping the oil off but I need to get this fixed.
Thank you in advance for your help and thanks to the many, many contributors here that have helped me keep her running as well as she does, without this forum I most likely would have lost her long ago!
All The Best & Cheers!!
This is many many startups worth of discharge. I power wash my driveway every weekend to keep it clean and get rid of this. This is about 5 days of start up discharge from the tail pipe. It's not "wet" but dry almost flakey
In addition I changed spark plugs, Ignition Coil, O2 Sensor
Not related but thought I'd also mention Master Cylinder replaced as well.
Background:
PCV Valve PCV2390
