1 - 4 of 4 Posts
I have an 05 xterra SE. I need to test my fuel pressure. Usually you can test it through the rail but I can't find a port. Is there any other way to test it?
There is no pressure relief port. You will need to break the line somewhere. Easiest would likely be where it mates up to the rail.
If you go through with this mod please post pics. I've needed to check pressure in the past and ended up just buying a new pump. So I guess I have a "spare" now. (It wasn't the fuel pressure)
1 - 4 of 4 Posts
