1 - 9 of 9 Posts
looking to do this to keep my tires from rubbing...when turning....coudnt find a write just want to make sure I do it correctly before I attempt this?
couldnt find it in the How too's...
thanks
It's in the "How To" thread here:
http://thenewx.org/phpbb2/viewtopic.php?t=2361
I took my Dremel and cut off that little metal lip part that MC talks about bending back. Then melted back most of the wheel well w/ my heat gun and even trimmed off some of the plastic at the very bottom. I had to melt just a little bit in the very front, too. Pretty easy mod overall.
Ahh, I was just copying the linky to the same write up.
Note, I added 285/75R16's 2 months ago and I have only had to do the melt part of the mod. I have MT's that are 33" and that is all I needed to do.
I just turned the tire, heated up the inner plastic, used a rubber mallet and a piece of 2x6 jammed between the tire and the hot piece of fender plastic and then let it cool. Had to do it 2 or 3 times per side, but no cutting of metal.
mcampana said:
Bueller, what kind of gas milage change did you get with those bigger tires?
I haven't figured it out, probably scared to. I was getting 346 miles on a tank of gas on the stock crap tires. Now I am getting about 300 miles on a tank. Factor in the bigger diamater tire makes about a 7% difference on the speedo. So I am getting about 321 miles per tank. Loss of 25 miles per tank.
Again, haven't figured out the MPG.
I love these tires though, they look awesome. People gawk at them when stopped at red lights. They are a bit noisy, but it is a truck. They have been great in the rain, haven't spun once, and I took them in the snow and I climbed up snow on mud hills no problem. They are great!!
Also I have the same suspension from PRG that you are running on the way. Hoping to see it by Friday!!!
Discussion Starter #7
I like this method better....I prefer not to cut the fender out...
Some people use a hair dryer...and some use a heat gun....which one did you use?
thanks
Heat gun. Tried the hair dryer but it took way to long. Went to Canadian Tire and found a good heat gun regular $45 on sale for $20.
Worked great!!
Discussion Starter #9
Worked great!!
I love Canadian tire....do you have Princess Auto's up near you?
1 - 9 of 9 Posts
