1 - 12 of 12 Posts
Timken from RockAuto.com. Best quality and best price. Normal hand tools are all you need.
I had to use a slide hammer to get mine out. 4 bolts on the back, pull the caliper rotor and caliper mount pull the axle nut and disconnect the abs sensor. Beat the snot out of it. This is where I used a slide hammer with a 10# weight on it.
When I replaced my front left bearing hub assembly last Feb I think it was... the hardest part was getting the abs sensor wire apart!!!! That was a bugger!!!! I'd soak it with penetrating fluid the night before as well. Will help it pop out better.
1 - 12 of 12 Posts
