Despite the extra stress these will likely cause, I've decided to install some 6-4.5 - 6-5/5 wheel adapters for 2 reasons; (1) the adapter should have a spacer effect and maybe prevent my 285/75/16s from rubbing against the rear frame rail under full articulation, and (2) it opens up my wheel options. I decided to order from ezaccessories, where Grunzen got his spacers.
For those who installed adapters, did the 1 inch do the trick (I've yet measure my wheel studs)? If not, how much grinding did you have to do? Any other problems? Would the 1.5 inch be better?
Thanks, everybody.
Thanks, everybody.
