i was looking for a place to mount my custom rear bumpers when i came across it.
:laughing3:dragonplayboy said:It's a yellow sticker.
X2mtdewmike said::laughing3:dragonplayboy said:It's a yellow sticker.
Do you have a write up for that mod?USMC XTERRA said:Yep a control box for the trailer lights. A lot of company's run the wire off the lights or supply. This adds load and drain to the circuit.
Nissan does the converter trick where they get only the signal from the supply in question, A separate power cable is run from the battery, into the converter and then the signal is brought from source and converter amplifies it and sends it to the trailer. This system gives you better power to your trailer lights and kind of separates it from the host system.
It's the best way to do it. Although you won't like the price should you damage that box.
I recently switched one over with a Hoppy unit on a Toyota, It will work, ya just have to figure out some wires. But lets not go there. I bet that box is in the 2 to 300 dollar range. Although I can make one for like $40.
MC
well thanks Captain Obvious! :drunken:dragonplayboy said:It's a yellow sticker.
