1 - 20 of 26 Posts
Who was that kid from Canada who did a bunch of work ... kind-of as a father/son project, maybe ... I have no idea what his screen name is, but he posted a ton during his build, then has dropped off a bit since. He had a shop build his bumper, they used LED fogs, but it looked a bit like that.
Otherwise I was going to say maybe KMA/TAG?
I think you're talking about Draconian.
Yessir ... I was thinking Dragon-something-or-other, but knew that wasn't right ... Draconian was the user I was thinking of. His bumper had a similar look to it, could be that the shop he used made another or has started making them to sell.
Draconian's bumper. I don't think it's the same builder, but could be.
Looks like Shrock. The 3 rivets in the radiator skid plate are the same as Shrock. The square holes in the radiator skid are a few more than their photos but are still the same as Shrock. Maybe it is a newer bumper from Shrock?
I just sent them an email and asked.
Will report back if I hear from them.
EDIT
Here's what they sent me:
WEST COAST PROJECT X...... TERRA
Niss tec Radflo Extended Travel Lift Kit:
• (2) Radflo 2.0 extended travel adjustable Coil Over’s – Fully adjustable from 0-4” of lift.
• (2) Extended travel SPC upper control arms
• 2) NissTec/Deaver rear 3” lift Add-A-Leafs w/ hardware – This custom longer rear AAL provides a great ride on and off-road, all while adding the ability to carry some extra weight on the back of your Xterra
• (2) Rear axle degree shims for proper pinion angle correction
• (2) Rear sway bar relocation brackets
• (4) New Longer zinc plated rear Ubolts
• (2) Bilstein 5100 series nitrogen charged rear shocks
Baja MTZ Radial 285-75-r16 (33” tall) Tires:
Extreme off-roaders will appreciate the great ride and handling that mud tire has on the highway. The MTZ has Mickey Thompson’s Power Ply TM sidewalls with a special angled third Ply to give you high performance handling, better puncture resistance, and improved towing capacity.
• Advanced Radial construction for high mileage and smooth ride
• Self cleaning high-void tread lugs for traction in mud and snow
• Deep Shoulder Lugs provide aggressive traction and bold looks
• Enhanced side biters for added traction & protection
Custom Front Winch Bumper
• Custom front winch bumper with upper grille guard
• Integrated lower skid plate that ties into bumper
• Retains OEM fog lights into front opening
• 3/16 material construction, lower weight, high strength
• Front D rings mounts for recovery/tow points
• Winch ready! Bumper will support up to a 9500lb winch
• Semi gloss, black powder coat for long lasting good looks!
RETAILS FOR $8,980.00
West Coast Price is only $6,698.00!
So..... Custom bumper.
1 - 20 of 26 Posts
