1 - 18 of 18 Posts
Pretty good amount of fluid in the area. Funny because the tail shaft seal is dry.
That seems like an excessive amount of fluid. Whatever is right under that joint looks soaked as well.
I dont know enough to give you any suggestions, maybe take it to the dealer?
I am going to have to take it to the dealer. Looks to be my rear seal. And looking at the service manual you need special tools to replace it. However, it should be a simple job!
whoaaa
Took it to the dealer turns out to be mud. I am a dumbass. Of course they wanted to change my rear brakes and do a fuel injection cleaning.
First question the dealer asked is if I go Off Road with the truck.
And you said??? There response was???
Hell ya!
My local dealer doesn't have to ask, they have a video running on a tv on their parts counter that has me crawling over some rocks and across a few creeks. :)
Discussion Starter · #11 ·
Unfortunately my dealer is not as "cool" as some other dealerships. But they gave me no hassles and I let them change some filters and my belt, but no my rear brakes.
Discussion Starter · #13 ·
BoonDox said:
That doesn't look like mud to me at all though.
To much a shine to it... Have tested to see if
its oily at all?
The dealer told me there was no leak and that is was mud. It is in their records. So if something breaks, then I can go back to them.
I'm new to Xterras so I'm going to ask a dumb question. I'm going to assume that there is a grease zerk fitting on that U-joint, Is this correct? If so then it is probably spin-off grease and dirt/mud combo. My 4runner has 5 spots like that under it.
Sorry, but looking at the picture, I'm finding it hard to believe that is mud.
But if there is no leaks, and it's in their records, then no worries for now.
It appears to be dust clinging to oil, but I didn't think that constitutes as being mud, well outside of Iraq at least.
Discussion Starter · #18 ·
Well it is pouring like a mother this weekend. So maybe next weekend I will climb under there and see how well it was cleaned up. Hit is with some brake cleaner and see if it re-appears.
1 - 18 of 18 Posts
