1 - 3 of 3 Posts
So first off let me list what i have than ill explain the issue
-Morimoto mini 6.0
-Morimoto MotoControl relay harness
-Ballast from Hues33 kit
onto the issue my high beams do not work with that current setup even if I reverse the polarity of the high beam connecter. I decided disconnect my relay harness to test and see if my high beams work with the normal halogen 9007 bulb and it does. So I had a crazy idea to reconnect everything and leave one halogen bulb connected to the left side 9007 connector (isnt required to be plugged into the MotoControl relay harness) and turned on my headlight. The highbeam automatically went on but its stuck in high beam and i cant disengage it. Once I take that halogen blub out the high beams disengage and no longer work. I am the original owner of the X and no other wiring has been messed around with.
Anyone seen this before? I have no clue as what to do next.
thanks in advance
Discussion Starter · #2 ·
figured it out, switch the cables on the relay 9007 connector to Red Blue White and it worked!
1 - 3 of 3 Posts
