1 - 5 of 5 Posts
I just purchased 65 watt H9 bulbs for my factory fog lights. All you need to do to install them is take a Dremel and grind out the extra small tab that the H9's have at the plug in point.
If you compare the h11 and H9 it is apparent what needs to be ground out. The extra 10 watts really made a difference. You can even use a regular (non HID look) bulb and it will appear super-white due to the extra wattage and the fact that there is no block coating on the end of the bulb.
No one makes a really nice H11 bulb yet because they are so new so I did this to increase my light output and appearance.
Fogs
Not if you adjust them correctly. I used my garage door to mark the light pattern as a base with the factory lights. I readjusted if necessary when I changed the bulbs.
1 - 5 of 5 Posts
