1 - 4 of 4 Posts
Hey guys, I've tried to find an answer with no avail. I have a 2011 PRO4X and have the Volant CAI and want to eventually install an Airflow Snorkel. One problem, the Volant that I have (been on for about a year and a half) has that weird cutout in the front right behind the horn; there is also a hole for the ram air duct, but that's easy to cap off.
So has anyone installed a snorkel with the volant that has that cutout in the front? If so how did you seal it off. I was thinking about bending some aluminum and riveting it shut and sealing it with silicone, but that seems like it'll be a pain. Any suggestions?
you could patch up that hole with some fiberglass, a bit essier then your option but makes a more water tight patch ( If done properly)
Keep the rubber coupling that comes with the "ram air" on the box and insert a plumber plug. I do this when wheelin and it works.
1 - 4 of 4 Posts
