Intro Comments: Hey all. Got the truck back in December of 2014. Been working on it ever since I saw this online forum. This has now become my addiction.
Year: 2010
Drive: 5 Speed, Automatic
Packages: 4x4, Towing package
Mileage:
December 2014: 39k miles
February 2018: 85k miles
[+] = Done
[-] = In progress
[ ] = Want/need to do
[+] 30 Channel Maxon CB Radio
[+] Yaesu FT-857D Ham Radio with Remote Kit/Upgraded Mic/External Speaker
[+] 2nd Indash 12v Power Outlet
[+] MOLLE Sunshade cover
[+] Multiple Maglites Mounted
[+] OEM Rear Cargo Retractable Cover
[+] WeatherTech All-Season Fitted Floor Mats for Front/Rear/Cargo
[+] Ram Mount Cell Phone Holder
[+] Power Inverter
[+] Fire Extinguisher
[+] Mesh Pockets for added Storage
[+] Cut and mounted OEM Light/Sunglasses/Bluetooth Panel
[+] Rocker Switches (Winch In/Out, Winch Power, Spot Lamps, Roof Bar, Fog Lights, CB/UHF, Roof Lights)
[+] Custom 100A BlueSea Fuse panel w/ 100Amp breaker and relays
[+] McMaster-Carr 175lb Rear Hatch Struts
[+] Garmin 60CSx GPS w/ Ram Mount
[+] ATP Cabin Filters
[+] 2x Hep Molle Rear Window Panel (Powdercoated Black)
[+] Lower Switch Panel Replacement and VDC Switch Relocation
[+] Heated Seats w/ Sports Imports Illuminated Hi/lo/off Round Rocker Switches (Prepping)
[+] Stealth EZPass Holder
[+] Custom Door Molle Panels w/ Biohazard Cutouts by 29erClan
[+] Custom Rear Cargo Rack by 29erClan
[+] Custom LoMo Rack by 29erClan
[+] Tire Tread Arm Rest Cover
[+] Nissan Seatbelt Shoulder Pads
[+] Black/Red Steering Wheel Cover
[+] Headliner Patch Collection
[+] A-Pillar Gauge Pod
[+] Accessory Fuse Panel Reset Fuse
[+] Removed OEM Side Step Rails & Mud Flaps
[+] Ventvisor Ventshades
[+] BFG AT KO2's x5 (285/75R16)
[+] Rear Bumper Offroad LED Lights
[+] LED Door Spotlights
[+] LED Offroad Roofbar
[+] Offroad LED Fog Lights
[+] 6500k LED Headlight & Fog Light Kits
[+] OEM Exterior Door Molding Panels (Blacked out)
[+] FireStik 3ft CB Antenna
[+] Comet Antenna Mounts
[+] Hood Bug Shield
[+] SouthCo Locking Wet Box Handle
[+] Warn External Battery Jumper Quick Connect Hookup
[+] Short Rugged AM/FM Antenna
[+] Taillight Grille Covers
[+] Tow Hitch w/ Multiple Balls
[+] Mini Wide-view Mirrors for Side Mirrors
[+] Trico ExactFit 14" Rear Wiper Blade
[+] Trico Force 20" (P) and 24" (D) Front Wiper Blades
[+] Removed Mud Flaps and Step Rails
[+] R1 Concepts Eline Series Cross-Drilled Slotted Rotors And Ceramic Pads Kit - Front and Rear
[+] Gorilla Automotive Acorn Black Chrome Wheel Locks & Small Diameter Acorn Black 5 Lug Kit
[+] Made Custom Brackets to mount my Shovel and Axe to the roof bar
[+] Shrockworks Front Bumper Replacement
[+] InSain Fab Rear Bumper Replacement with Tire Carrier
[+] Full Gobi Rear Hatch Ladder
[+] Zombie Burger Front Emblem
[+] Red Trail Rated Badges
[+] Poison Syder 14-53-010 Hood Louver (Painted Black)
[+] Hefty Sliders with Tread Plates
[+] AirFlow Snorkel
[+] Trasharoo
[+] RotopaX 2 Gallon Gas Can w/ custom made mount
[+] Front and Rear Bottle Cap Openers
[+] Gates "31836" Locking Gas Cap
[+] Vouke "V-S002 4R4A" Smoked Front & Rear Side Marker Lights
[+] Raingler 2.5" Roof Rack Grab Handles
[+] Obsidian Fabrications Roof Light Bracket w/ 4x LED Kingdom Light Cubes
[+] Rear Side Step Traction Plates
[+] ProComp 7089 16"x8" Wheels
[+] Colby Valves Ultimate Tire Valves
[+] DIY Red-Cabled Limb Risers
[+] Bedlined Undercarraige to protect against winter road salt
[+] Custom Ground Power Connection
[+] Battery Kill Switch
[+] Accessories Kill Switch
Suspension & Steering:
[+] Alcan Custom Rear Leaf Pack rated (+450lbs w/ 2.5" lift)
[+] PRG 1/2" Lift Spacers (switching to 2" Nisstec Top Spacer)
[+] PRG Shim Kit
[+] PRG Ubolt Flip Kit
[+] PRG Cam Bolt Kit
[+] PRG Adjustable VHS Red Shackles
[+] Bilstein Rear 5125 Series Rear Shocks (w/ 4-5" Lift)
[+] RadFlo 2.0 Front Coilover Kit w/ Grade 8 Bolts (Coilover Shocks & Springs / 650lb)
[+] PRG Red UCAs, Rev 2
[+] Timbren Active Offroad Front and Rear Bumper Stops
[+] Removed Front & Rear Anti-Sway Bars
[+] Mevotech LCAs
[+] Moog Front AntiSway Bar Bushings
[+] Moog Wheel Hub Assemblys
[+] Moog Inner & Outer Tie Rods
[+] M226 Rear Axle Carrier Swap w/ 3.69 Gears and E-Locker
[+] R180 Swap with 3.69 Gears and Lokka Locker
[-] Ricochet Polyurethane Rack & Pinion Busings
[+] Nisstec Rear Shock Skids (Red)
[+] Shrockworks Radiator Skid Plate
[+] Hefty Engine/Oil Pan Skid Plate
[+] Hefty Transmission Skid Plate
[+] Hefty Transfer Case Skid Plate
[+] Hefty Gas Tank Skid Plate
[+] 4x4Parts.com M226 Diff Skid Plate
[+] Hefty Sliders w/ Tread Plates
[+] M226 ARB Cover
[+] M226 Skid Plate
Engine and Drivetrain:
[+] Nismo Billet Oil Cap in Red
[+] Billet Radiator Cap Cover in Red
[+] Hood Rod Elimination Kit
[+] Femco Quick Drain Oil Plug Kit
[+] Odyssey Extreme 34R-PC1500T Battery
[+] Custom made Billet Battery Tie Down Painted Red made by Fresh Prince
[+] Multi-Port Negative Terminal Adapter
[+] Multi-Port Positive Terminal Adapter
[+] Volant 12740 Sealed CAI
[+] AEM PreFilter
[+] Dewhel Universal Cylindrical JDM 750ml Aluminum Engine Oil Catch Can Reservoir Tank (Red)
[+] Radiator Bypass and Torqflo Secondary Transmission Oil Cooler & Derale 9" DynoCool Fan
[+] Airaid PowerAid Throttle Body Spacer in Red
[+] XTP Intake Manifold Spacer in Red
[+] Hayden Oil Filter Relocation Kit
[-] Offroad Gorilla Red Silicone Cooling Hoses
[-] Spicer Rear Driveshaft 1330 U-Joint
[+] NGK Laser Iridium Spark Plugs
[+] R180 w/ 3.69 Gears & Lokka, Diff Breather & Filter
[+] M226 w/ 3.69 Gears, Diff Breather & Filter and ARB Cover
[-] Tom Woods Custom Double Cardon Driveshaft
Recovery Gear:
[+] Tow Strap
[+] Hi-Lift Jack with Stand/Boot/Clamp/Jack Mate
[+] Bumper Mounted Shackles
[+] Additional Shackles
[+] Warn M8000-S Winch
[+] Warn Black Hawse Fairlead
[+] Warn Wireless Controller Kit
[+] Warn 18k lb Epic Winch Hook
[+] Factor55 Red UltraLink Loaded Shackle Mount
[+] 30ft 30k lb Tow Strap
[+] 3", 8' Tree Saver, Winch Strap 30k lb Capacity
[+] MAXTRAX MKII in Red w/ Mounting Pin Kit
Misc: (Gotta show some Zombie love)
[+] Zombie Apocalypse Response Team Seat Covers
[+] Zombie Stickers/Decals
[+] Biohazard Wheel Stem Caps
Factory Recalls:
[+] Side Curtain Airbag Reprogramming
Achievements Unlocked: (X-Score: 512 pts)
Year: 2010
Mileage:
[+] = Done
[-] = In progress
[+] Power Inverter
[+] Hood Bug Shield
[+] AirFlow Snorkel
[+] Trasharoo
[+] PRG Shim Kit
[+] Mevotech LCAs
[+] M226 ARB Cover
[+] M226 Skid Plate
[+] AEM PreFilter
Recovery Gear:
[+] Tow Strap
Factory Recalls:
- The Unseeable Volume (5 pts) Activate low wiper fluid light
- Rip van Winkle (7 pts) Sleep in your Xterra (by bigollurch)
- Wide Load (50 pts) Tow over capacity (inspired by ryandavenport and Loki512)
- Flytrap (5 pts) Add over thirty stickers (individual letters in a line of text do not count towards total, nor do registration stickers or parking passes)
- Sneaky (5 pts) Stealthed rims, plastics, rails, or bumpers
- Low Clearance (10 pts) Hit your head somewhere inside the Xterra (inspired by Dead*reckoned and tim13con)
- MC Hammer (10 pts) Develop rear suspension sag
- BDUV (10 pts) Add camouflage accessories (inspired by piratex)
- Bought Some Rubbers (10 pts) Fit 33" tires or larger. (by Alpine X)
- TactiCool (15 points) Add "tactical" gear to your Xterra. Flashlights, tools, and firearms by themselves do not qualify. (inspired by MTBXjunkie)
- Armory (30 points) Add permanent/semi-permanent firearms stowage.
- Let There Be Light (20 pts) One lighting upgrade. May include: LED interior lights, dashboard LED swap, at least two additional fog/driving lights (OEM fogs count on lower-trim Xterras), HID retrofit. Lights may face any direction. Portable lighting does not count. Does not stack.
- Prometheus (25 pts) LED light bar (Does not stack)
- Mutt (20 pts) Full set of mixed armor (bumpers, skids, sliders). Must have complete set.
- Shields Up! (20 pts) Acquire aftermarket steel bumpers
- Holy (30 pts) Add a snorkel (inspired by rook)
- Escape Pod (5 pts) Find the backup forum.
- Swiss Cheese (30 pts) Drill five or more holes in your Xterra (inspired by rook)
- Everest (5 pts) Get high-centered
- Tripod (10 pts) Achieve a three-wheeling stance
- I've Fallen (20 pts) Get stuck
- ...and I Can't Get Up (30 pts) Achieve I've Fallen needing recovery from another vehicle
- Arête'd Development (10 pts) Scrape a rock (Inspired by 11Pro4X)
- Gold Digger (20 pts) Contact 10 or more rock formations in a single trail (tire contact does not count)
- Can You Hear Me Now? (20 pts) Damage your CB antenna on a trail
- Here's My Card (5 pts) Inspire an Xterra owner to join an Xterra forum. Does not stack.
- Atlantean (50 pts) Participate in East Coast Xterra Challenge
- Cold Shoulder (20 pts) Get hung up on a snow bank
- And Going And Going And Gone (20 pts)*Deplete primary vehicle battery
- Tesla (15 pts)*Create an electical issue
- Skidmark (5 pts)*Scratch a skid plate down to the steel
