Intro Comments: Hello Everyone, I just got my Xterra on 12-9-2017 with 86k miles. It's completely stock right now. I'm going to change the radiator with an aftermarket one to prevent the SMOD issue. Eventually I will start offroading, but I'm new to this world so I don't even know where to start. I have a 2008 Infiniti G37 coupe and it's my weekend car now that I have the X. I'm addicted to modding my G37 since it has exhaust, test pipes, intakes, tune, air suspension, retrofitted headlights, carbon fiber hood/trunk etc. so I know the X won't stay stock for long sigh here we go again. lmao
Username: Vizard
Instagram: Mall_Crawling_X
Xterra's Nickname: Mall Crawling X
Year: 2005
Trim: SE 4x4 5AT
Color: Night Armor (K26)
MODS:
Wheels/Tires:
-Black Rhino Chambers (17x8.5 0 offset) (Used for Offroading 35's)
-Pro Comp 89 17x8 -12 offset (Daily Driving on 33's)
-Yokohama Geolandar MT G003 (35X12.5R17)
-Front Fender Trim (Top/Rear)
-Spidertrax 1.5” (WHS025) Wheel Spacers (rear only)
Engine:
-VK56 Swap
-Airraid Air Intake + Xterra Volant CAI Closed Box #12740
-JBA Long Tube Headers
-Cajun Titan Resonated B Pipes 2.5"
-Cajun Titan Y Pipe 2.5"
-OEM Exhaust Gaskets
-JBA Catback Exhaust
-Red Silicone Coolant Hose Set
-UpRev Tune (314whp/363tq)
-Audi R8 Coil Pack
-Plug n Play wire harness
-NGK #4469 LFR5AIX-11 Iridium IX spark plugs
-SDHQ Built Billet Battery Terminal Upgrade Kit
Brakes:
-RAYBESTOS Front Rotors 980628R (V8 Pathfinder swap)
-RAYBESTOS Front Pads EHT888AH (V8 Pathfinder swap) (Inner Plate Length 6.190”)
-POWER STOP Front Calipers S3714 (V8 Pathfinder Swap Fronts) (12.6” (320mm)
-RAYBESTOS Rear Pads EHT1094H (Xterra OEM)
-POWER STOP S2994 Rear Calipers (Xterra OEM)
-AllDogs Offroad Rear Diff Breather Kit
-All Dogs Offroad Stainless Steel Brake Lines 20"
Suspension: Titan Swapped
-Radflo 2.5 w/ remote reservoir 650 lbs red springs (Titan Length)
-Radflo 2.5 w/ remote reservoir extended travel rear (Titan Length)
-SPC 25560 Upper Control Arms (Titan Length)
-Mevotech Supreme LCA CMS30116 (Titan Length)
-Mevotech Supreme LCA CMS30117 (Titan Length)
-SURTRACK/TRAKMOTIVE CV Axles NI8203 x2 (Titan Length)
-Daystar KN09107BK Extended Length Shackles 1.5"
-MS30703 Inner Tie Rods x2 (Titan Length)
-MS30606 Right Outter Tie Rod (Titan Length)
-MS30605 Left Outter Tie Rod (Titan Length)
-NissTec 2” Add-A-Leafs
-Front Camber Bolts
-Steel Axle Degree Shims
-Extended U-Bolts
-SPC UCA bolts
-2015 Nissan Titan Pro4X M205 3 Rib 3.36 (23k miles)
-2014 Nissan Frontier Pro4X M226 3.36 w/ E-Locker rebuilt w/ new bearings/seals (100k miles)
-Spicer E-Locker Harness Kit (#10021771)
-Rear ABS Lines for M226
-Timbren Active Off-Road Bump Stops (rear)
-Sony XAV-AX100 touchscreen
-Uniden Pro 520 XL
-4' Firestik FS CB Antenna
-18' Premium RG8X CB Coax Cable
-Heavy Duty CB Antenna Spring
-Firestik CB Antenna Quick Disconnect
- White Knuckle Offroad Rock Sliders
- DOM tube steel
- Matte Black Powder Coat
- Angled 25 degrees
Lighting:
Accessories:
Auxbeam LED Light Bar Wiring Harness Kit w/ fuse relay (need to install)
Auxbeam 20" LED Light Bar 126W (need to install)
40" Double Row LED Light Bar CREE - 400W 34,200 LUMENS (need to install)
Trackspec GT2 Hood Vent (need to install)
Wish List:
PD90
TransGo Shift Kit HD2
All Dogs Offroad Broverland
Max Gear Rear Bumper with swing arm/tire carrier
Removed:
-RAYBESTOS 980370 Advanced Tech Rotors (Fronts)
-RAYBESTOS Pads EHT1094H (Fronts)
-POWER STOP Calipers S3122A (Fronts)
-BF Goodrich TA KO2 285/70/17
-OEM 17" SE Wheels (Plasti Dipped)
-Spidertrax 1.5" wheel spacers SOLD
-Side Step and Mud Flaps
-2.5" Rough Country (never installed) SOLD
-Air Raid Intake Filter
-PRG Rear Diff Breather Kit (Broke)
-Nisstec Stainless Steel Extended Brake Lines
-Nisstec MK84 Front Coilovers 550lbs
-Radflo 2.0 Rear Emulsion Shocks
-SPC UCA SOLD
-Mevotech LCA
Maintenance:
Replaced Radiator around 88k miles
Passenger Brake line needed to be replaced
Regular Oil Change at 90,783 miles (6-1-18)
Calipers/Brake pads/rotors at 92,982 (7-30-18)
Replaced Battery at 93,540 (9-3-18)
Oil Change at 95,000 (10-15-18)
Camshaft sensors, bank 1&2 at 96,971 (11-24-18)
Tie Rods 97,450 (12-1418)
Wheel Bearings Assembly 97,450 (12-14-18)
Wheel Alignment 97,450 (12-14-18)
Fuel Pump/Fuel Sending Unit 98,000 (1-3-19)
Oil Change at 98,910 (1-23-19)
VK56 swap at 100,350 miles (Feb/2019) picked up on 3-24-19
Transmission Fluid Change done with vk swap
Cooling System Fluid Change done with vk swap
Oil Change done with vk swap
Nisstec Stainless Steel Extended Brake Lines 4-20-19 (103k miles)
Oil Change at 108,500 (7-15-19)
Oil Change at 113k (1-11-20)
Replaced 4WD U Joints at 115k miles (2-1-20)
Power Steering Pump at 118k miles (6-5-20)
Drive Belt Replaced at 118k miles (6-5-20)
Oil Change at 118k miles (6-5-20)
R8 Coilpacks at 118k miles (6-5-20)
Titan Swap Install 119k miles (7-20-20)
M205 Gear Oil at 119k miles (7-20-20)
M226 Gear Oil at 120k miles (8-21-20)
New front Wheel Bearings at 121k miles (9-17-20)
VK56 SWAP PARTS
2010 Titan Engine under 120k miles
2010 Titan 4wd Transmission under 120k miles
2007-12 Titan Engine Harness (Used, Converted)
2007-12 Titan Engine Control Module
UpRev Tune
Titan Motor Mount Brackets
Titan Powersteering Pump (Used)
Titan AC Compressor (Used)
Titan AC Compressor to Condenser Line
Pathfinder V8 Low Suction AC Line
Titan Powersteering Pressure Line
Titan Engine to Transmission Bolts
Titan Flexplate (Used)
Titan Clutch Fan - upgraded to electric fan
Serpentine Belt
Titan Fan Blade (Used)
Heather Core Fitting
Titan Lower Radiator Hose
Titan Upper Radiator Hose
Pathfinder V8 Radiator Shroud
Pathfinder V8 AC Fan
Titan Coilpacks
Titan Transmission Dip Stick
Titan Starter
PRG Polyureathane Titan Motor Mounts
PRG Polyureathane Titan Transmission Mount
Titan Engine Cover
OEM Exhaust Gaskets
JBA Catback Exhaust
Username: Vizard
Year: 2005
Trim: SE 4x4 5AT
MODS:
Wheels/Tires:
Engine:
-VK56 Swap
-Audi R8 Coil Pack
Brakes:
-Front Camber Bolts
-Extended U-Bolts
-SPC UCA bolts
-Uniden Pro 520 XL
- Raingler Ceiling Cargo Net (Mesh)
- DOM tube steel
- Angled 25 degrees
- ARB 0750008 Red Differential Cover M226
- Hefty Fabworks Front Tube Winch Bumper (No Hoop)
- Hefty Fabworks Aluminum Radiator Skid
Lighting:
- Retrofitted Headlights:
- MH1 Projector Retro-fit (Bixenon Projectors-NHK HID bulbs)
- Morimoto RGB Halos
- RGB Demon Eyes
- Black paint
- Diode Dynamic SS3 Max Fog Lights (Flood Pattern)
- Diode Dynamic SS3 Pro Ditch Lights (Combo Pattern)
- Diode Dynamic Pro SS5 (Spot) x2
- Diode Dynamic Pro SS5 (Driving)x2
- Diode Dynamic Map/Dome Lights (HP6 LED Bulbs)
- Rago Fabrication Ditch Light Brackets
- Switch Pro SP-9100 Panel
Accessories:
- ARB 12v twin on board Air Compressor
- ARB Tire Inflation Kit
- ARB Digital Tire Inflator
- ARB 4296 Air Inflation Carry Case
- Smittybilt Rapid Air Deflator
- Raingler Seatback Handle x2
- Rotopax 2Gal Fuel Can
- 48" All Cast Hi-Lift Jack
- 2"- 3" adjustable tube mounts & Handle Keeper
- Hi-Lift Jack NJC Neoprene Jack Cover
- ARB Awning 2000
- Fourtreks Modular Awning Mounts
- ARB Deluxe Awning Room
- Gobi Shrockworks Ladder
- Gear America Aluminium Ultra Bow Shackles w/ AntiTheft Locking Pin (Red)
- Gear America Aluminum Ultra Shackle Hitch w/ Locking Pin (Red)
- Midland MXT575 GMRS Radio
- Midland Micromobile MXTA26 6db Antenna
- Midland Micromobile MXTA27 Universal Lip Mount
- CAT6A Female to Female Adapter
- CAT6 Ethernet Cable 7’
Wish List:
PD90
Removed:
-SPC UCA SOLD
-Mevotech LCA
Maintenance:
VK56 SWAP PARTS
UpRev Tune
Serpentine Belt
Titan Coilpacks
Titan Starter
Titan Engine Cover
OEM Exhaust Gaskets
JBA Catback Exhaust
