Sorry, I actually did a search and I see I wasn't the only one. Has anyone found a definitive solution?
Thanks Muzik. I just want to make sure the drivetrain does fall off or something while I'm driving it :blackeye: .Muzikman said:This seems to be a common problem with no solution. If you do a quick search you'll see quite a few people having this problem currently. I think I read a while back that the problem ended up being a bad wire harness, but not positive on that.
Do you know where you may have seen this, as my dealership is qlueless.Muzikman said:I think I read a while back that the problem ended up being a bad wire harness, but not positive on that.
